Power Analysis of an Unknown Device in a Series AC Circuit Setup
In an AC circuit with an ideal voltmeter and ammeter in series with an unknown device, the power delivered to the device can be expressed as P = Irms * Vrms. However, this value may not represent the actual power dissipated if the load is reactive, as reactive components do not consume real power. The discussion highlights the distinction between apparent power and true power, emphasizing that the presence of capacitors or inductors can affect the measurements. Therefore, without additional information about the load, the true power cannot be determined solely from the rms values. Understanding the nature of the load is crucial for accurate power analysis in AC circuits.
nontypicalazn
hi, I am wondering if anyone can answer this question of the following circuit setup, thanks:
an AC source connected parallel to a volt meter, together in series with an ampmeter, then series with some sort of device. No numbers are given. Volt and Amp meters are both ideal. What is the power delivered to (across, dissipated by, would there be any difference) unknown device, relative to Irms * Vrms.
thank you.
i uploaded a scheme.
http://img215.imageshack.us/img215/9852/untitledml4.jpg
thanks
thank you.
thanks
You already gave the answer, P = Irms * Vrms. Power is delivered to or dissipated by the device (not "across").
thank you.
thanks
I'm not sure what the point of your question is. There is a concept of "apparent power" that can be measured with your rms meters, but that may not be telling you the true power delivered to the load. If the load is purely reactive, no power is actually delivered.
Here is a rather clear discussion of the problem.
http://www.ibiblio.org/obp/electricCircuits/AC/AC_11.html
well, that's what I am kinda asking. This unknown device is not defined. but generally speaking, what is the power dissipated by the load?
is it equal to IV
less than IV
or possibly equal to IV even when capacitors and inductors are present?
Oops, I wasn't thinking of reactive loads. My bad :blushing:
is it equal to IV
less than IV
The link I posted takes you through the possibilities. You cannot tell with your rms meters the true power being dissipated.
