Power and Energy of a motor problem
The discussion revolves around calculating the average power developed by a motor lifting a 400-kilogram mass at constant speed over a vertical distance of 10 meters in 8 seconds. Key equations include P = W/t and P = Fv, with W representing work and F representing force. The challenge lies in understanding that while the mass is lifted at constant speed (indicating zero net acceleration), the gravitational force acting on it must still be considered. Participants emphasize the importance of identifying all forces acting on the mass and correctly applying the relevant equations to solve for power. Ultimately, the correct approach involves recognizing the relationship between force, work, and power in the context of constant velocity lifting.
majormuss
What is the average power developed by a motor
as it lifts a 400.-kilogram mass at constant speed
through a vertical distance of 10.0 meters in
8.0 seconds?
(1) 320 W (3) 4,900 W
(2) 500 W (4) 32,000 W
P=Wd/t= Fd/t= mad/t
How does the fact that acceleration is 0 change the way I should approach this question. The question says acceleration is constant.
On the other hand I tried using this formula... P=Fv... but because I don't know acceleration, I can't find 'F'.
The correct equation for power is: P=W/t
What is work? (W=Fd)
What is force? (F = ma)
In this problem, there are 2 accelerations to consider: (1) The problem says the speed is constant so the acceleration of the mass as it travels through space is 0. (2) assuming that this motor is operating near the surface of the Earth, the acceleration due to Earth's gravity is acting on the mass.
8.0 seconds?
P=Wd/t= Fd/t= mad/t
Fv should work as well as wd/t, because d/t = v. To find the force, draw a force body diagram. What forces are acting on the 400kg object? Remember, force does not equal acceleration. A NET force equals an acceleration.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
