Calculating Power Dissipation in Series Lightbulb Circuit
  • Thread starter Thread starter BuBbLeS01
    Power
In a series circuit with two 97 W lightbulbs connected to a 114 V supply, the total resistance is 228 ohms. The current through the circuit is calculated as 0.5 A using the formula I = E/Req. Each bulb dissipates power calculated by P = VI, resulting in 57 W per bulb. However, this calculation is incorrect as it does not account for the voltage drop across each bulb in series. Proper analysis shows that each bulb actually dissipates less power due to the shared voltage, leading to a need for reevaluation of the calculations.
BuBbLeS01
Power...Did I do this right??
Two 97 W (114 V) lightbulbs are wired in series, then the combination is connected to a 114 V supply. How much power is dissipated by each bulb?
P = VI
I = E/Req
I = 114/228 =0.5
P = 0.5 * 114 = 57
Is this right?
Oh my gosh its wrong! Why am I not getting these Power problems right! I thought that was the equation...
solved...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
