Finding the 26th Derivative of g(x) at 0
  • Thread starter R_Y_A_N
  • Tags
    Derivative
In summary: The power series might help you identify the higher order derivatives. By symmetry you can argue that the odd derivatives are zero, but not the evens.
R_Y_A_N
Given:
/ (sinx)/x for x =/= 0​
g(x)=
\ 1 for x=0​
(26)
g(0), the 26th derivative of g at 0 (Hint: can you find a power series for g(x)?)
At zero the function is 1 right?...so the first or second or 26th derivative is zero...right? but that seems way to easy..please help me understand why i need to use a power series...thanks
The first derivative at zero is zero, but not the second. The power series might help you identify the higher order derivatives. By symmetry you can argue that the odd derivatives are zero, but not the evens.
This reasoning is wrong -- remember that the derivative of a function at a point depends on the values near that point... and the function isn't 1 everywhere near that point.
The power series of sin (about 0) is sin(x)~x-x^3/3!+x^5/5!-x^7/7!+...+(-1)^k x^(2k+1)/(2k+1)!+...(k the number of the nonzero term)
x g(x)=sin(x)
So you should be able to find a power series for g. You will also see that all the derivatives are not zero.
I think what confused you is
f'(1) is not the same as (f(1))'
like if f(x)=x^2
f'(x)=2x f'(1)=2 (f(1))'=(1)'=0
but for a power series...you need to take all the derivatives of the function up to the 26th..and that get's messy..do i really have to take the 26th derivative of sinx/x?
The goal of the problem is to use the power series to find the derivatives, not the other way around. You need to find the power series through some other method...
y' = (-x^-2)(sinx) + (x^-1)(cosx)
y'' = (2x^-3)(sinx) + (-2x^-2)(cosx) - (x^-1)(sinx)
y''' = (-6x^-4)(sinx) + (6x^-3)(cosx) + (3x^-2)(sinx) - (x^-1)(cosx)
i don't see a pattern..maybe I'm doing something wrong...or maybe I'm just blind
i'm getting very confused now...you use the derivatives to make a power series to approximate the value at that point..so to find a power series to find the 26th derivative would require me to find the 26th derivative to make the power series by definition right?
Perhaps you should try paying attention to the responses you already have:
You've already been told that
sin x= x- (1/3!)x^3+ (1/5!)x^5- 1/(7!)x^7+...- (1/27!)x^27+ ...
so (sin x)/x= 1- (1/3!)x^2+ (1/5!)x^4- 1/(7!)x^6+ ... - (1/27!)x^26+ ...
Of course, the nth coefficient of the MacLaurin series for any function g(n) is
(1/n!)g(n)(0). So what is g(26)(0)?
The higher derivatives often get messy. For this reason it is often easier to deduce a power series from another known one. In this case you know the power series for sin(x) and you want to find the power series of g(x) where x*g(x)=sin(x).
for example (1-x)^-1~1+x+x^2+x^3+x^4+x^5+...
x/(1-x)~x+x^2+x^3+x^4+x^5+x^6+...
See a pattern?
Have you covered formal operations on power series such as multiplication, division, and addition?
so it's 0^26 or 1?
no i haven't unfortunately
R_Y_A_N said:
so it's 0^26 or 1?
So the idea is is f and g have power series you can often find the power series of f/g by dividing their power series. This can some time be tricky but in your problem we have x which has a simple power series (just x). So the general term in sin(x) is (-1)^k*x^(2k+1)/(2k+1)! The general term in sin(x)/x is then (-1)^k*x^(2k)/(2k+1)! The 2k-th term is also [tex]g}^{(2k)}{(0)}*x^{2k}/(2k)![/tex]
So you should be able to figure out what the 26th derivative of g at 0 is.
so, if I'm understanding this correctly, all the derivatives will be either -1 or 1, depending on whether (-1) is raised to an even or odd power, and in this case we raise (-1) to the 26/2 or 13 power and get -1 as the 26th derivative at zero
No, lurflurf just told you that "the general term in sin(x) is (-1)^k*x^(2k+1)/(2k+1)!" so the general term in sin(x)/x is (-1)^k*x^(2k)/(2k+1)! and that "The 2k-th term is also [tex]g}^{(2k)}{(0)}*x^{2k}/(2k)![/tex]". Equate the two:
(-1)^k*x2k/(2k+1)!= g(2k)(0)x2k/(2k)!. Solving for g(2k), g2k(0)= (-1)k(2k+1).
Here is another way to find the derivatives without power series.
x g(x)=sin(x)
take k+1 derivatives
[tex]x g}^{(k+1)}{(x)}+(k+1) g}^{(k)}{(x)}=sin}^{(k+1)}{(x)}[/tex]
let x=0
[tex](k+1) g}^{(k)}{(0)}=sin}^{(k+1)}{(0)}=cos{(k {\pi}/2)}[/tex]
[tex]g}^{(k)}{(0)}=\frac{{sin}^{(k+1)}{(0)}}{k+1}=\frac{cos{(k {\pi}/2)}}{k+1}[/tex]
Now try to see how it works with power series.
see that
g(0)=1
g'(0)=0
g''(0)=-1/3
g'''(0)=0
g''''(0)=1/5
What is the 26th derivative of g(x) at 0?
The 26th derivative of g(x) at 0 is the 26th derivative of the function g(x) evaluated at x=0. It represents the rate of change of the 25th derivative of g(x) at 0.
Why is it important to find the 26th derivative of g(x) at 0?
Finding the 26th derivative at 0 can provide insights into the behavior of the function g(x) at that specific point. It can also be useful in solving higher-order differential equations and understanding the overall curvature and shape of the function.
How do you find the 26th derivative of g(x) at 0?
To find the 26th derivative of g(x) at 0, you can use the general formula for finding derivatives or the chain rule. It involves taking the 25th derivative and then evaluating it at x=0. This process can be repeated until the 26th derivative is reached.
What is the significance of evaluating the 26th derivative of g(x) at 0?
Evaluating the 26th derivative at 0 can provide information about the local behavior of the function g(x) at that point. It can also help in determining the growth rate of the function and its higher-order derivatives.
Can the 26th derivative of g(x) at 0 be negative?
Yes, the 26th derivative of g(x) at 0 can be negative. This indicates a decreasing rate of change of the 25th derivative at 0, which can correspond to a concave down or decreasing behavior of the function g(x) at that point.
