What is the Energy Transmitted by a Plane EM Wave Passing Through a Window?
The discussion focuses on calculating the energy transmitted by a plane electromagnetic (EM) wave passing through a window. The electric field of the wave is given, and the amplitude of the magnetic field is derived using Maxwell's equations, resulting in a value of 0.13 A/m. For energy transmission, the average energy of the wave is calculated using the Poynting vector, leading to 0.597 kJ when the wave is incident normally and 0.517 kJ at an angle of 30 degrees. The calculations are verified by confirming the relationship between the electric and magnetic fields aligns with the speed of light. Overall, the thread provides a detailed approach to solving the problem using fundamental physics principles.
Wesley Strik
In free space, the electric field of a plane EM wave is given by: E(z,t)= 50î cos[wt-kz]
where w= 6 x 10^15
and k=2x10^7
(A) calculate the amplitude of the magnetic field H
How much energy does this wave transmit in 30s when it passes through a window of dimensions 2mx3m if the EM wave is incident:
(b) normally on the window
(c) obliquely at an angle of 30 degrees with respect to the window normal
Maxwell:
curl E= dB/dt
--------------- relation H and B---
H=B/mu0
mu0=4pi x 10 ^-7
For (A) I relate the two fields via the Maxwell curl E= dB/dt which yields:
50k j cos(wt-kz) = w B
such that B= 50k/w cos (wt-kz)
the amplitude becomes 50k/w=(10^9)/(6x10^15)= 1/6 x 10^-6
now relate this to H=B/mu0 ---> (1/6 x 10^-6)/(4pi x 10^-7)= (10/6) / (4pi) =0.13 A/m
did I d (A) correclty, does the outcome make sense?
Also, I have no clue how to do (b) and (c)?
anyone?
Okay so I found an equation for the average energy of a plane wave:
<S>= Em2/(2 c μ0) where c is the speed of light, mu the magnetic permeability of free space, Em=50 in this case. <S> is the averaged Poyting vector, such that ENERGY=<S> *area* time, which gives me, when I plug in the numbers: (area =3x2, t=30s)
for (b) I get: 0.597 kJ
for (c) I get: Cos[π/6] *0.859=0.517 kJ
*** I checked my Bm field of (a) by checking that Em/Bm=c=3x10^8, which it did, so I assume I can divide by mu naught correctly
