Preliminary stress and vibration analysis of turbine blade
Preliminary stress and vibration analysis of turbine blades is complex due to unique geometries and operating conditions, with cyclic fatigue being a primary concern. A thorough understanding of structural and modal analysis is essential, and there is no one-size-fits-all approach. Beginners are advised to start with basic assumptions, treating the turbine blade as a cantilevered beam before adding complexity. Utilizing industry literature and seeking guidance from academic advisors can help in formulating a structured approach. Simplified calculations may be necessary due to time constraints, but they will involve numerous assumptions.
everybody
helo guys,i'm new here hope to gain knowledge from this forum.i currently doing a project about design of turbofan engine.now i have to do preliminary stress and vibration analysis for the turbine blade.i'm not very good at stress and vibration and have search the internet about it but couldn't find any good reference about this.do anyone can recommend any text or reference book that describe clearly about this?your help is really appreciated.
Regards,
everybody
Oy. If you're not very good at structural analysis and modl analysis, you sure picked a doozie of a project.
Cut to the chase, there is no cookie cutter method for doing what you want to do. The process for analyzing turbine blades is complex due to their operating environment and very peculiar geometries. You can further complicate this because cyclic fatigue is the primary concern with turbines. It takes a lot of hours developing models and then extensive numerical analysis to get meaningful results. However, no matter how difficult, the basics in both areas still remain. For example, if you want to make a very long list (I do mean a LONG list) of assumptions, you can say that a turbine blade is, essentially, a cantillevered beam. Start with something you should have seen before. Then add complexety to your analysis in small steps.
Stress analysis and modal analysis are pretty broad topics. I would suggest you do some searching for industry literature in your school's library and try to formulate your own approach with the help of your advisor. Once you get there you will be able to ask
Thanks for the reply.Actually, i with my other two friends were given 4 months to finish this project.this project really give me headache.I want to do the simplified calculation only due to limited time and i know it will be lot of assumption .anyway thanks for ur advice.. :)
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
