Can I Convert PSI to kPa Using Dimensional Analysis?
  • Thread starter Thread starter JoeMaxwell92
    Pressure
The discussion centers on converting psi to kPa using dimensional analysis, specifically addressing the challenges of interpreting pounds as force versus mass. The conversion from psi to kPa is clarified, noting that 1 psi equals approximately 6.9 kPa, while 1 kPa is about 0.145 psi. It emphasizes that direct conversion from pounds to Newtons requires a clear definition of units and the gravitational acceleration constant. The conversation concludes that understanding unit definitions and conversion factors is crucial for accurate dimensional analysis. Overall, the thread highlights the importance of proper unit interpretation in pressure conversions.
JoeMaxwell92
Ok, so I was at lowes and I was trying to figure out the gauge pressure of a certain air compressor that used psi measurements. I don't have an iPhone or anything that can pull up internet converters so I figured I would have to do the conversion dimensionally. This posed a problem though as the pounds to kilograms converter on my phone doesn't recognize pounds as a force, but as a mass. I was wondering if there was some sort of calculus involved with dimensionally converting psi to kPa.
1 lb = .4536 kg_{in Earth's gravity}
with respect to time, pressure is the second derivative of kg/meter
an object with a mass of 0.4536 kg has a weight of 1 pound on Planet Earth (that's about 4.45 Newtons).
No need for calculus...1 psi is 1 pound/square inch...convert pounds to kN (1 pound is 0.00445 kN) and convert square inches to square meters , and you end up with 1 psi is 6.9 kPa, or 1 kPa is 0.145 psi, approximately.
So I guess what you are saying is there is no way of converting pounds directly into Newtons by dimensional analysis without a definition, in Newtons, of what a pound is, or without multiplying the conversion from lbs to kg by the gravitational acceleration constant?
That's right, you need a definition. It's all in the definition of the unit and the conversion factors between units. That is true even within the chosen system of measure itself. For example, a kN is the force required to accelerate 1000 kg of mass at a rate of 1 meter per second per second. But you first need to define the kilogram and meter and second per an international standard.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
