Pressure and flow rate relationship
The discussion centers on the relationship between pressure and flow rate in a pipe, specifically questioning whether a flow rate drop from 8000 gpm to 4000 gpm would result in a pressure of 27.5 psig from an initial 55 psig. It is noted that if the flow is turbulent, the pressure drop will be more significant than half, potentially around three-quarters. Additionally, a user seeks guidance on calculating the flow rate of air through a 12 mm diameter pipe at a pressure of 7 kg/cm². The thread is over two years old and has been closed, with a suggestion to start a new thread in the homework forums and conduct prior research. The conversation highlights the complexities of fluid dynamics and the need for proper methodology in problem-solving.
mfholbac
If I 8000 gpm flowing in a pipe, and know that pressure of the water is 55psig, will the pressure be 27.5psig if the flow rate through the same pipe drops to 4000gpm.
Hi mfholbac. Welcome to Physics Forums.
I assume you mean that the inlet pressure is 55 psig, and the outlet is into the atmosphere at 0 psig. If the flow is turbulent, which I assume will be the case in your system, then the pressure will drop more that just half-way, but a little less than 3/4 of the way.
Chet
Sir, Kindly let me know how to calculate flow rate (cfm or Litre/m) of air flowing through a pipe of 12 mm dia from a reservoir at pressure 7 kg/cm2 to atmosphere.
i.e ;- how much volume of compressed air could pass within a minute through a "X" mm dia pipe from a constant pressure (7 kg/cm2)
This thread is over 2 years old, with no new responses. Please start a new thread. I am closing this one.
Please put your new thread in one of the homework forums, and use the template. Also, please do some literature search on your own before posting, to get an idea how to address a problem like this. The homework template will ask you to show your thinking and effort so far.
Chet
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
