Pressure distribution of buoyancy force
To convert buoyancy force into pressure for a fully submerged solid cylinder, the pressure at any point can be calculated using the formula ρgh, where ρ is the fluid density and h is the height from the fluid surface. The resultant force from the pressure acting on the cylinder's surface equates to the buoyant force. The density used in calculations should be that of the fluid, and the height should be measured from the fluid surface to the point of interest on the cylinder. Clarifications on the reference point and the specific density differences were discussed, emphasizing the importance of accurate height measurement. Understanding these parameters is crucial for effective finite element analysis in this context.
flyingbird
Let's say we have a solid cylinder which is fully submerged in water or any fluid having density lower than of cylinder's density. I want to find out how can we convert the buoyancy force in terms of pressure. Actually I am doing FE analysis of this kind of problem and software allows to apply pressure loads only. How can we find out the buoyancy pressure distribution along the radial hight of the cylinder. Cylinder is kept in horizontal position just as a submarine in water.
Thanks
FB
Thanks
FB
The resultant force from the pressure acting on the surface of the body is the buoyant force.
The pressure at any point in a fluid is equal to \rho gh.
CS
CS
Which density we have to use here?
is it difference between two densities?
And what hight will be used here? what is the reference point?
I have tried this, I don't think it is a correct way to do it.
The 'rho' term in the equation is the density of the fluid. The height is the point at which you wish to know the pressure referenced from the top of the fluid surface.
CS
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
