Pressure increase in room connected to cannister
The discussion revolves around calculating the pressure increase in a room connected to a helium canister, particularly in the event of a failure of a flow restrictor. Participants explore the implications of pressure dynamics, flow rates, and the application of various equations in this context.
  • One participant proposes using the Hagen-Poiseuille equation to calculate the volume flow rate and pressure drop, expressing uncertainty about the approach.
  • Another participant suggests using the ideal gas law and the compressibility factor to determine the total mass of helium and the resulting pressure in the room.
  • A later reply indicates that the Hagen-Poiseuille equation may not be suitable due to the turbulent flow conditions, suggesting the use of the Darcy-Weisbach equation instead.
  • Participants discuss the potential for choked flow if the downstream pressure drops significantly, emphasizing the importance of understanding flow dynamics in the system.
Participants express differing opinions on the appropriate equations to use for calculating flow and pressure changes, indicating that there is no consensus on the best approach to the problem.
There are unresolved assumptions regarding the flow characteristics and the specific arrangement of components in the system, which may affect the calculations and outcomes.
This discussion may be useful for individuals interested in fluid dynamics, gas behavior under pressure, and practical applications of gas laws in engineering contexts.
alibo
Hello,
I wondered if anyone could provide a bit of guidance.
I have a Helium cannister at 500bar pressure with a flow restrictor supplying Helium at 8 bar pressure to a room of 24m^3 at 1 bar pressure. The Helium flows down a 50m pipe. I want to calculate the pressure increase in the room due to the Helium in the event that the flow restrictor fails and the entire 500bar pressure is exerted on the pipe.
I have used the Hagen-Poiseuille equation to get an expression for the volume flow rate and the pressure drop, however I have not performed these kinds of calculations before and so I am unsure if I am going down the correct path.
My initial thoughts were to take the normal pressure drop between the cannister and the room as 7 bar, then calculate the volume flow rate due to this pressure drop. In a given time of an hour, the pressure in the room should increase from Pair to Pair + Phelium. The pressure of the helium can be calculated using the ideal gas law equation PV=nRT. The process can then be repeated with the higher pressure of 500 bar.
This route seems riddled with holes to me. Is there a more simple/accurate approach to the problem?
Welcome to PF.
You could probably get a reasonably accurate answer as follows.
If you know the volume of your helium canister, use the perfect gas law to figure out the total mass of helium in the canister. You can use the 'Z' compressibility factor for improved accuracy.
Assume that eventually all this helium will end up in the 24 m^3 room. Find the partial pressure of helium from PV = mRT. Then add Pair + Phelium to get your final pressure.
Thanks, that's the solution I hit on in the end!
The next issue is that I want to add a flow restrictor to reduce the pressure in the pipe. The room can evacuate 50m3/hr of gas, which equates to 0.014 m3/s. I want to restrict the flow entering the room to this level to prevent the pressure increasing.
I thought that the Hagen-Poiseuille equation would work, but it appears to be only useful for laminar flow. The Reynold's number for this setup puts it firmly in the turbulent category, so should I use the Darcy-Weisbach equation?
For your flow restriction, were you going to use an orifice, a valve, or just striaght pipe? Both compressibility and viscous effect will be important.
With your pressure differences, your flow will likely be choked (limited by the speed of sound). For any component, if the downstream pressure drops below about 50% of the inlet pressure, the flow will be choked.
So let me know your arrangement, and we can go from there.
  • · Replies 45 ·
