Calculating Liquid Mass in a Vat with Varying Diameter and Depth
  • Thread starter Thread starter jkb
    Liquid Pressure
To calculate the mass of liquid in a vat with a diameter of 1.90 m and a depth of 2.70 m, the volume must first be determined. Although the assumption was made that the vat is cylindrical, the pressure at the bottom suggests a need for careful consideration of the shape. The formula for density, ρ = m/V, requires accurate volume measurements, which may not apply if the vat's diameter varies. The discussion highlights confusion over the vat's shape and the correct volume calculation method. Accurate identification of the vat's geometry is essential for determining the liquid mass correctly.
jkb
A 1.90 m-diameter vat of liquid is 2.70 m deep. The pressure at the bottom of the vat is 1.30 atm. What is the mass of the liquid in the vat?
I found the density of the fluid but now I'm stuck and I really can't get my mind around this even though i know its going to turn out being so easy...thanks the help in advance!
Density is given by
\rho = \frac{m}{V}
so you need to determine the volume of liquid in the vat.
Well, since a vat can isn't necessarily a cylinder how would I go about doing that? I tried to assume the vat was a cylinder and found that volume but the answer wasn't correct.
why do you say that? what makes you think it is not a cylinder?
Well i used the volume of a cylinder formula and found the volume and then using the density i found the mass but that answer was incorrect and i don't think i made any mistakes in the calculation so that's where i got stuck...
oops, nevermind me
well the problem stated that there was a diameter and a depth IE an cylinder. can you show us your work?
It is not really sensible to talk of a diameter if it changes. Unless there is a mathematical formula for calculating the volume of such a vat shaped object.
9K
