Pressure of stacked bricks question
  • Thread starter Thread starter Sabres151
    Pressure
The discussion revolves around calculating the mass and pressure exerted by a stack of lead bricks. The mass was correctly calculated as 272,160 kg using the volume and mass density of lead. For pressure calculations, it was clarified that the area in contact with the floor is crucial, and maximum pressure occurs with the smallest area while minimum pressure occurs with the largest area. There was confusion regarding the use of mass density versus weight density, emphasizing the need to account for gravitational force in pressure calculations. Ultimately, understanding the relationship between weight, area, and pressure is essential for solving the problem accurately.
Sabres151
I'm having difficulty with the part b.
Question: A stack of lead bricks measures 2.00m by 3.00m by 4.00m
a) Find the mass of the bricks.
b) Find the maximum and minimum possible pressures on the floor under the bricks in Pa and atm.
a)
A = 2m(3m)(4m)
A = 24m^3
mass = V(D)
Weight Density of lead = 11,340 kg/m^3
m = 24m^3(11,340 kg/m^3)
m = 272,160 kg.
b)...I'm thrown off by figuring minimum and maximum. Do I start with
P = F/A ??
a)
A = 2m(3m)(4m)
A = 24m^3
mass = V(D)
m = 272,160 kg.
P = F/A ??
By A I think you mean V (volume). The units for your density suggest that is mass density, not weight density. If so, there has to be a g in your calculations. I don't see an area calculation in your work, bu tyou need area to find pressure. The stack has the same wight no matter how you arrange the bricks. The maximum pressure will be with the smallest area in contact with the floor, and the minuimum pressure will be with the greatest area in contact with the floor.
Dan, thank you for the response. Yes, you are correct, by A, I should have V. And...should the calculation for the mass of the bricks be using weight density rather than mass density? I used mass density...
You need the weight of the stack of bricks to find the pressure. The pressure would be different on the moon than it is on earth. It is easy to get the weight from the total mass, so you have all the information you need.
Ok, now I'm really lost. For Area, I have 24 meters cubed. To find the mass of the bricks I was using the Mass Density of lead (11,340kg/m^3).
Since m = V x D I have a mass of 272,160kg.
24meters cubed is the volume, and that is what you need to find the mass. How do you find the weight when you know the mass? The stack of bricks is in the shape of a rectange. Each face of the rectangle has an area. Any one of the faces could be on the bottom. The pressure is the weight divided by the area.
