Pressure on uniformly charge spherical shell
timhunderwood
First part of the problem was to work out E-field of uniformly charged spherical shell with charge Q and Radius R.
This was fine : E = 0 for r<R
and E = Q/(4*Pi*eps*r2) for r>R
QUESTION:
Find the pressure exerted on the shell due to the charges on its surface.
I tried to do it using the principle of virtual work, I get an answer and was hoping someone could confirm it is right?
I did this:
u_s, Energy stored in Electric field = \inteps*E2/2 (integrate over all space)
I did this in spherical polar coordinates and get U_s = Q2/(8*Pi*eps*R)
I then said (principle of virtual work:)
F, Force*dR = \partialU_s/\partialR *dR
and solved this to get:
F = -Q2/(8*Pi*eps*R2)
dividing by area of shell then gives
pressure = Q2/(32*Pi2*eps*R2)
is this right? If there's a mistake I think I may have not used the principle of virtual work correctly...
Thanks very much.
I do believe you are making this a little more complicated than necessary. The electrostatic pressure on the surface is given by the formula
P=\frac{\varepsilon_0}{2}E^2
(cf. Griffiths Equation 2.52)
You're missing a factor of R^2 in the denominator, but otherwise, yes, that is fine.
Thats good,
I mistyped my last equation- it should have read R^4.
Thanks for the help
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
