Is Pressure Directly Proportional to Temperature in Gases?
  • Thread starter Thread starter hasan_researc
    Pressure
Pressure is directly proportional to temperature for a fixed volume of gas, as stated in the lecture notes. The relationship is expressed mathematically as P = P0(1 + αt), where α is approximately 1/273 when using the Celsius scale. This proportionality holds true for ideal gases or under low pressure and moderate temperatures. The value of α is derived experimentally and relates to the concept of absolute zero. The discussion raises questions about the nature of this relationship and the definition of absolute zero.
hasan_researc
My lecturer writes the following in his lecture notes:
" P \propto t for a fixed volume of gas,
P = P0(1+\alphat)
Using the Celcius scale of temperature, we find \alpha \cong 1/273."
Is P really proportional to t?
How do we find \alpha \cong 1/273 using the Celcius temp scale?
Correct
P = P0(1+\alphat)
Just another way of writing the above,
Yes - for an ideal gas or at low pressure and reasonable temperatures.
Experimentally - it's the definition of absolute zero
If P \alpha t for a fixed volume of gas, then should P not equal \alpha t, instead of being equal to a constant P-nought times the sum of 1 and \alpha t?
How can it be the definition of absolute zero?
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
