Pressure Vessel Maximum Diameter Calculation
The discussion centers on calculating the maximum diameter of a pressure vessel given specific loading and internal pressure values. The longitudinal joint strength is 33 kips/ft, while the internal pressure is stated as 150 psi. The calculations involve using the formula for stress, leading to the conclusion that the maximum diameter is approximately 3.06 ft or 36.67 inches. Participants express concerns about the learning process, emphasizing the importance of understanding the problem rather than just obtaining answers. The conversation highlights the balance between providing help and encouraging independent problem-solving skills.
tsukuba
The strength of longitudinal joint in Fig. 1-17 is 33 kips/ft, whereas for the girth is 16 kips/ft. Calculate the maximum diameter of the cylinder tank if the internal pressure is 150 psi. - See more at:
http://www.mathalino.com/reviewer/m...blem-138-pressure-vessel#sthash.G52XwZOd.dpuf
σlongitudinal = Pr / 2t
I have no way of calculating this since I have 2 unknowns. If you go to the link you can see the steps they've done but it doesn't make sense. Also, where does that 21600 come from?
Look at their solution. The 21600 is in the place p in an expression of the form
pD/(2t). This is the 150 psi expressed in lb/ft^2 to be dimensionally consistent
isnt p =125 psi? and why is there a second t under 33000
p = 150 psi, the internal pressure, as is stated clearly in the problem statement.
The longitudinal joint can withstand a maximum loading of 33 kip/ft according to the problem statement. The stress on this joint is then the loading divided by the thickness of the pressure vessel, t, so
σ = w / t = 33,000 / t
But also σ = pD/2t, so these equations can be combined thus
33,000 / t = σ = pD / 2t
The t's cancel, leaving pD/2 = 33,000, or D = 2 * 33,000 / (150 * 144) = 3.06 ft. = 36.67 in.
Check your units.
There are 2 formulas to calculate pressure in a vessel. Pr / 2t and Pr/t
when it doesn't say calculate the circumferential or the longitudinal stress how do I know which one to use?
p = 150 lbf/in2*144 in2/ft2 = 21600 lbf/ft2
w = 33 kip / ft = 33000 lbf / ft
D = 2 w / p = 2 * (33000 lbf / ft) / 21600 lbf / ft2 = 3.06 ft = 36.67 in
Units checked.
SteamKing, the comment to check units was intended for the OP. No one doubts that you know how to work this simple problem. I was under the perhaps mistaken impression that our purpose here was to help the OP learn, to be able to think through the problem, rather than to just display our own brilliance.
I see in this case, that even given a full solution, the OP is not inclined work through it, but rather simply comes back with more simple questions. I think that, in cases like that, it is better not to give full answers, but only to offer hints.
Dr. D, this is not my homework. I have a test this week and I look for other sources to help me. I was not given much help at school from the teacher so I have to find my own way of learning and practicing. These could be simple to you but they aren't to me. SteamKing has been nice enough, and the only one that has helped me understand a lot, and I feel that without his help I'd still be stuck.
  1. tsukuba, you may think that SteamKing has done you a great favor, but I don't think so. It makes no difference whether this is homework, review for a test, or what; it is clearly an academic sort of problem. You started this whole discussion with a fully worked solution available to you, one that any well prepared engineering student should have been able to follow. The whole point of a learning exercise, whether for HW or test review, is for you to learn how to think through the problem. With all the help you had available to you (full solution with the original problem, tips I offered trying to lead you to think through the problem), and you still did not get it until SteamKing spelled out every minute detail for you, I doubt that you have learned very much at all. If this exact problem appears on the test, you may be able to get an answer. If a similar, but slightly different problem appears, I doubt greatly that you will be able to do much with it. That's why I don't think SteamKing has done you any great favor. You have not been pushed to think the problem through as you needed. Good luck with your test.
