Equivalence of Time Dilation in Different Gravitational and Accelerating Frames
In summary, the principle of equivalence is only sustained when the fundamental measure of acceleration (in this case, the rate of time dilation) differs. Two clocks in a gravitational field, separated by any height - will not experience the same acceleration - nor the same dilation.
  • #71
That is a logical contradiction. If the distance is not changing then the only way to get a redshift is to have time dilation. I refer you back to post 55.
assume segment AB move into a *uniform* gravitational field which is perpendicular to the uniform motion of segment AB.
-------------------UGF-------------->
^^^^ A--------B ^^^^
why would there be a time dilation between A and B?
A redshift is needed since there is still energy gained or lost moving
from A/B to B/A.
Of course, UGF and field with a boundary are just hypothetical, not encounterred in practice.
  • #72
kev, check DaleSpam's revision of my diagram in #62. I think it will bring you up to speed on my point.
Mentz114 said:
Your logic is too tortuous for me.
It's a strange way to communicate, asserting that if I disgree with proposition A then I'll be claiming that proposition B is true etc. How do you know what I'll be claiming ? Maybe your logic is faulty and I'll claim something completely different.
Mentz114, it shouldn't difficult or tortuous. I simply meant if you do not agree with the constancy of the speed of light then you are claiming the speed of light is not constant. Which in my opinion requires explanation.
Its all hand waving if you can't state whatever your problem is in equations.
Equations are not the problem, as previously thought. The problem is stating the observations from B's perspective without including external information that leads to the temptation of irrelevant equations.
The external information needed to confirm acceleration with respect to an inertial frame and set up the thought experiment in context of the principle of equivalence is "not" information that B (the test observer) possesses when considering the time of light signals.
stillwonder, I don't know if you're speaking to me. If so you seem to be missing a few points made earlier,
we are not talking about spectral shifts.
  • #73
Equations are the problem: specifically that you still can't derive any to prove your point.
  • #74
from A/B to B/A.
Since the disance is constant the redshift is due to time dilation.
  • #75
Chrisc said:
My claim has always been that the time between A0 and B0 as measured by B, is less than B's calculation of H/c and larger than the time between A1 and B1 measured by B.
This is a huge problem. If you honestly believe that this is the same claim you have been making throughout this thread then it is plain that you don't even understand the terminology. Your claim has always been that the time dilation of A relative to B is time varying. In this scenario time dilation is the ratio of A1-A0 as measured by A to B1-B0 as measured by B. It is not "the time between A0 and B0 as measured by B".
Since you are so fond of the "if you don't agree with X then you will be making the claim that Y" form of argument, then I will post my own:
If you do not clearly and rigorously derive your claim from first principles then you will be making the claim that your assertions are illogical.
  • #76
kev said:
Are we specifically analysing:
1) Born rigid acceleration
The case of an accelerating rocket that has greater acceleration at the rear than at the tail at any given instant according to a non accelerating observer. That same obeserver would measure the rocket to be length contracting progressively more over time. An observer on the ship would measure the proper length of the ship to remain constant over time. Observers on the rocket would notice that an accelerometer indicates greater proper acceleration at the tail than at the nose.
2) Bell type acceleration.
The case of accelerating rocket that has equal acceleration at the nose and at the tail at any given instant, according to a non accelerating observer. That same observer would say the length of the rocket remains constant over time while an observer onboard the rocket would consider the rocket to be getting longer over time. Observers on the rocket would notice that an accelerometer indicates the same proper acceleration at the tail than at the nose.
DaleSpam said:
The proper distance (in the accelerating frame) was stipulated to be constant in https://www.physicsforums.com/showpost.php?p=1743187&postcount=7". So it is Born rigid acceleration.
OK, I have uploaded a spacetime diagram for Born-rigid type acceleration. In the digaram it can be seen that signals sent at regular intervals of 15.88 seconds from the rear of the rocket (as timed by a clock at the rear of the rocket) will arrive at the nose of the rocket (in this example) at regular intervals of 21.02 seconds as timed by the observer at the nose of the rocket. In other words the time dilation and red shift of internal signals observed inside the rocket undergoing Born-rigid acceleration remains constant over time. I used the equation of acceleration described here http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html which take length contraction, time dilation, syncronicity and changing acceleration over time (as observered by the non accelerating observer into account. (Almost none of these things are taken into account by the diagram posted by Chrisc.
On the other hand it can be shown that an observer at the nose of a rocket undergoing Bell type acceleration WILL see the clock at the rear of the rocket get progressively slower over time, while the the observer riding at the rear of the rocket will see the clock at the nose progressively speeding up over time. Therefore redshift of internal signals is not constant over time in this model, which can be described as the equivalent of a uniform gravitational field. The second diagram shows the proper time of the arrival of the signals at the nose of the rocket when signals are sent at regular intervals from the tail of the rocket undergoing Bell type acceleration.
  • #77
Thanks kev, these are excellent diagrams. The most important thing for Chrisc to note here is that the one effect that he repeatedly mentioned, the progressive reduction in time between emission at the front and reception at the back, is included in this diagram. That effect, by itself, does not imply a time varying time dilation.
The important thing for Chrisc to note here is that the proper distance is increasing. So the equivalent gravitational situation would be that H is increasing also. Since the gravitational time dilation depends on H then in such a case the time dilation in the gravitational field would also be non-constant.
There is no reason to expect that the equivalence principle would not hold in either case.
  • #78
Thanks kev, your diagrams are very helpful and address the crux of my question.
They also show my question should have been qualified in context of a "uniform" gravitational field.
DaleSpam, I take it you're saying I have compared the equivalence of a "uniform" field
with Bell type acceleration, instead of Born type. In other words an accurate comparison
of equivalence should be either "uniform field - Born type acceleration" or "non-uniform field - Bell type"
That does make sense, but I'm not sure it resolves the problem.
My question is a matter of principle. I am very stubborn when it comes
to principles (and I am grateful for your patience) which is why this thought
experiment has always caused me angst.
kev, in your description of Bell type acceleration you mention the observer
onboard the rocket would "consider" the rocket to be getting longer
over time. This is what DaleSpam has been telling me.
Can you explain or point me to where I can find an explanation
of the line of reasoning that justifies this conclusion of length contraction?
I was under the impression the length of the rocket could only be determined as a
measure of time, which would require some principle (or least metaphysical
modeling) to make the leap from decreased rate of time to increased length.
  • #79
of equivalence should be either "uniform field - Born type acceleration" or "non-uniform field - Bell type" ...
I think it should be the other way round. A Uniform field is the same as Bell type acceleration because the proper acceleration anywhere in the rocket (or the field) is measured to be the same. In Bell type acceleration the proper acceleration at the rear is greater than the at the front so that represents a non uniform gravitational field. I think also there is some confusion as to just what is meant by a uniform gravitational field. Some people seem to use it in the context of uniform horizontally (so that objects without initial horizontal motion all fall parallel to each other) and are not too concerned with changes in acceleration with height. I prefer to think a uniform gravitational field is unvarying with height and horizontal position. I would love to know what the official definition is.
In this thread https://www.physicsforums.com/showthread.php?t=236681 I posted another spacetime diagram that attempts to make the Bell's spaceship paradox easy to understand, along with links to more complete articles on the subject. Feel free to ask more questions in that thread if still puzzled. It is one of the more tricky subjects in relativity, more so because it less commonly addressed than paradoxes like the twins for example. The implications of applying the Equivalence principle to the Bell's type situation leads to some pretty bizarre conclusions that makes it difficult to be absolutely confident about what should happen in the gravitational equivalent. The implication seems to be that everything physical in such a field would be ripped apart including the gravitational body that is responsible for the uniform field. I am still puzzling over that one ;)
  • #80
Chrisc said:
kev,
actually yes, since i stumbled into similar contradiction thru a separate path
i noticed you were equating non uniform Gfiled with uniform acceleration, hence
the comment.
but as it turned out, the formulae have been cleverly retrofitted to take care of
redshift/time dilation wrt uniform / non-uniform G fields
  • #81
kev, thanks, I will look into both and follow up with the links your mentioned.
I've been too busy to get back to it and I will be for a few days. But I wanted to take a minute to thank you for your help.
DaleSpam, I also want to thank you again for your help and patience. I know it must be frustrating to go through so many post of this nature. I am grateful you did not give up. If you hadn't kept pushing me to derive my point, I wouldn't have seen your point (Bell vs Born).
stillwonder, sorry for the confusion. I will post more about this later when I have time, as I am not convinced of the "cleverness" argument.
