Probability of Repeated Coin Toss Results on the Nth Toss | Coin Toss Homework
  • Thread starter ArcanaNoir
  • Tags
    Probability
In summary, the conversation discusses finding the probability of getting the same outcome twice in a row when tossing a coin. It involves using a geometric series to sum up the probabilities of getting the same outcome on different tosses. The final answer is \frac{1}{2^{n-1}} and the probability of this event occurring on an even toss is \frac{1}{2^{1}}+\frac{1}{2^{3}} + \frac{1}{2^{5}} + \frac{1}{2^{7}} + \ldots. The conversation also touches on the importance of always having a positive attitude and being open to learning and looking things up when needed.
ArcanaNoir
779
A coin is tossed until the same result appears twice in a row. Find the probability that this event occurs on the nth toss.
(the answer is [itex] \frac{1}{2^{n-1}} [/itex])
I made a tree and first only considered the results of the 2, 3, 4..ect toss that did not have the same result twice in a row. I kept getting 1/2. When I included ALL the results on the 3, 4, 5 etc toss, I did not get something equivalent to the answer.
In the first n - 1 tosses, what must the distribution of outcomes be?
1/2 heads, 1/2 tails?
That is true, but not sufficient. Can you have:
HHHTTT
for example?
EDIT:
Actually, if n - 1 is odd, it isn't even true.
Of course
ArcanaNoir said:
Of course
Of course what?
Of course you can have HHHTTT
but if you toss unti lyou get the same twice in a row, maybe you can't have hhhttt
So, can you or can't you? Think before you type.
Okay how about I don't know? When I tried both ways I still got the wrong numbers.
Lol. So, let's say that in the 7th toss you got the same outcome as in the 6th toss, but never before that. What are the possible ways of tossing the coin (in all previous trials)?
HTHTHTT or THTHTHH
True. What is the probability that any of these events will occur (use conditional probability)?
(2/2)(1/2)(1/2)(1/2)(1/2)(1/2)(1/2) ?
Why do you have 2/2 in the first factor?
Cause we could start either heads or tails.
Oh, so you went one step beyond my question and evaluated the TOTAL probability of the two union of the two favorable events. Ok, so if you count the powers of 2 in the denominator, you will get 1/26.
Can you generalize this pattern if we change 7 in our example with a general integer n? What do you get?
I got, it right? I easily see how (2/2)(1/2)(1/2)(1/2)(1/2)(1/2)(1/2) = [itex] \frac{1}{2^{7-1}} [/itex]
Yes, so the point is that if you knew that you had a double toss in the nth trial and you know what you had, you can go back and trace your whole tossing history. But, you can have HH or TT as a double toss, so this increases your favorable outcomes by a factor of 2.
Note: It is not that easy to do it with a dice, for example. :wink:
thank you very much for the help!
i didn't do anything. I was just chatting with you. You did all the work.
But you got me in the right direction. I just stared at it otherwise.
So, what's the probability that this event occurs on an even toss? Answer is 2/3
I see that it's can't happen on the first (an odd) toss, and then after that it's almost like 50/50. But how do I find 2/3?
No, this is not true. It does not matter if its an even or odd toss. The point is that (n-1)-st is the same as n-th and they alternate if you go backwards after that. So, for n = 6 (even) you would have:
HTHTHH
THTHTT
What isn't true? That occurring on an even toss is 2/3? This is what the book says.
OOOhhhhh, on ANY even toss.
Yes, well that is the probability of occurring on the 3rd (it cannot on the 1st cause you didn't make 2 tosses yet), 5th, 7th, etc.
Using your formula you need to evaluate the geometric series:
[tex]
\frac{1}{2^{3 - 1}} + \frac{1}{2^{5 - 1}} + \frac{1}{2^{7 - 1}} + \ldots
[/tex]
If you know how to sum these, then you will get the answer from the book.
So the probability that it occurs on an EVEN toss is [tex] \frac{1}{2^{1}}+\frac{1}{2^{3}} + \frac{1}{2^{5}} + \frac{1}{2^{7}} + \ldots [/tex]
So... how DO I sum that?
It says in your avatar that you have and Undergrad in Mathematics. Surely you know how to sum geometric series. That is something you learn in Senior High School.
You're cruel. So I forgot! Sheesh. [tex] \frac{1}{a-r} [/tex] or somthing. Fine, I'll look it up.
Yes, this is the right attitude. Always! BTW, what you had posted is incorrect.
Yes, I see that... *trudges up the stairs to get stewie's calculus*
  • #31
Cool. Got it. Thanks again!
1. What is the probability of getting heads on the Nth coin toss?
The probability of getting heads on the Nth coin toss is always 50%, assuming the coin is fair and the previous tosses do not affect the outcome of the current toss. This is because there are only two possible outcomes - heads or tails - and each outcome has an equal chance of occurring.
2. How does the probability change with each coin toss?
The probability of getting heads on the Nth coin toss does not change with each toss. Each coin toss is an independent event and the probability of getting heads remains at 50% regardless of the previous outcomes.
3. What is the probability of getting a specific sequence of heads and tails in N coin tosses?
The probability of getting a specific sequence of heads and tails in N coin tosses is calculated by multiplying the individual probabilities of each outcome. For example, the probability of getting heads on the first toss and tails on the second toss is 0.5 x 0.5 = 0.25 or 25%.
4. How many coin tosses are needed to get a certain number of heads in a row?
The number of coin tosses needed to get a certain number of heads in a row depends on the probability of getting heads on each toss. The probability of getting N heads in a row is 0.5 to the power of N. So, for example, the probability of getting 3 heads in a row is 0.5 x 0.5 x 0.5 = 0.125 or 12.5%. Therefore, on average, it would take 8 coin tosses to get 3 heads in a row.
5. Can the probability of getting heads on the Nth coin toss be greater than 50%?
No, the probability of getting heads on the Nth coin toss cannot be greater than 50%. This is because the coin toss is a random event and the probability of each outcome is always 50%. However, if the coin is biased, the probability of getting heads may be greater or less than 50%, but this would not be a fair coin toss.
