Probability (involving conditioning)
  • Thread starter Thread starter bennyska
    Probability
bennyska
a deck of cards is shuffled and then divided into two halves of 26 cards each. a card is drawn from one of the halves; it turns out to be an ace. the ace is then placed in the second half-deck. the half is then shuffled, and a card is drawn from it. compute the probability that this drawn card is an ace.
{hint: condition on whether or not the interchanged card is selected.
so at first, i was totally lost. i did a google search, and found another physicsforums thread that went over this question. (https://www.physicsforums.com/showthread.php?t=174152). the solution for the most part made sense to me. however, I'm confused by the original hint, condition on whether or not the interchanged card is selected. what exactly does that mean? and is there another way to solve the problem, other than the solution on the other page?
hi bennyska! :wink:
i doubt it :redface:
hmm … "for the most part" ? :redface:
i think the best thing is for you to write out the proof (in your own words) as far as you can, and then we'll see where you're getting stuck! :smile:
(use the P(A|B) terminology)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
