Probability of all elements question
mutzy188
If P(A) =0.4, P(B)=0.5, and P(A∪B)=0.7, find P(A’∪B’)
P(A’) = (Probability of all elements in S that are not in A) = 1 - P(A) = 0.6
P(B’) = (Probability of all elements in S that are not in B) = 1 – P(B) = 0.5
P(A’∪B’)= The union of A’ and B’ = 1 - 0.7 = 0.3
P(A’∪B’) = P(A’) + P(B’) – P(A’∩ B’) = 0.6 + 0.5 – 0.3 = 0.8
So, P(A’∪B’) = 0.8
I'm not sure if i did this correctly.
Thanks
How do you know P(A’∩ B’) = 0.3?
The easiest method is to figure P(A ∩ B). (Can you tell me why?)
I just assumed that you could do that.
P(A ∩ B) = .4 + .5 - .7 = .2
So would P(A' ∩ B') = 1 - .2 = .8 ?
You're correct but you seem to be bent on making this too difficult =P. P(A intersect B) = P(A) * P(B) = 0.4 * 0.5 = 0.2
I know you probably get this all the time, but drawing pictures for these things really does help. Or even just visualizing a Venn Diagram for these events in your head. You can see that the complement of (A' union B') is (A intersect B) and P(A intersect B) is easy to find.
Correct; and that's exactly how I would have calculated this.
No. P(A ∩ B)' = 1 - .2 = .8 is correct. What is the relationship between (A ∩ B)' and A' U B' ?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
