Probability of Tying Grass Together
  • Thread starter Thread starter HKfish
    Probability
The problem involves determining the probability of forming a large circular loop by randomly tying the ends of three indistinguishable blades of grass. Each blade has two ends, resulting in six ends that appear unrelated. The task is to find the probability of a specific pairing arrangement that leads to a loop and to generalize this for n blades of grass.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the total number of arrangements (6!) for tying the grass and question how to account for specific arrangements that lead to a loop. There is also consideration of labeling the ends to clarify the arrangement possibilities.
Participants are actively exploring the problem, with some attempting to calculate the total arrangements and others suggesting ways to simplify the problem by considering the complement of the desired event. There is no explicit consensus yet, but various interpretations and approaches are being discussed.
There is a mention of the need to account for indistinguishability and the specific conditions under which a loop is formed, which may affect the calculations. Participants are also navigating the complexity of pairing arrangements.
HKfish
Each of three indistinguishable blades of grass are bent roughly at their midpoints and clasped by these midpoints so that an observer can't match any of the ends in any way. In other words, all six ends are just dangling and appear completely unrelated. Suppose you are asked to tie the ends together (which, given the stipulations, can only be done randomly by selecting one pair at a time). First, determine the probability, as a reduced fraction, that a large circular loop results, and then, generalize for n blades of grass.
I have no idea what angle I should attempt this question at. If someone could just decipher this question for me it is much appreciated!
It is asking for the probability that one end of blade A is tied to one end of blade B, the other end of B is tied to one end of C and the other end of C is tied to the other end of A---so you form a big loop. Of course, the order could instead be ACB, and either end of each blade can be chosen each time.
Thanks for the reply! So, I attempted the question and figured out there is 6! ways of tying the grass (total). Now the problem is how do I figure out the factors to take out of the total? Thanks for your reply!
Rather than simplifying it and then accounting for various things, it might be clearer what you need to do if you label the ends
A1 A2 B1 B2 C1 C2
And consider how many different ways there are to arrange this such that A1 is next to A2, B1 is next to B2 and C2 is next C3
And remember that A1A2B1B2C1C2 is different to A1A2B1B2C2C1
Once you start writing these out you should see ways of simplifying the problem
You might also think about what it must mean if the *complement* of the desired event were to occur; that is, think of what must happen if the grasses do NOT form a large loop.
Rather less. It's just a matter of arranging the 6 ends into pairs.
21K
9K
  • · Replies 44 ·
12K
  • · Replies 94 ·
15K
  • · Replies 17 ·
9K
