Problem - find second derivative
jkristia
The problem and my attempt at a solution is shown in the attached image.
The problem is that I end up with one extra x in the denominator.
So the question is: Is my expression for y'' correct and I just made a mistake somewhere (I have checked it several times), or am I missing something in the expression for y' and/or y'' ?
If the answer in the book is something like 6/x^3 + 18/x^4 + 12/x^5, you got the same answer.
[ IMG]https://www.physicsforums.com/attachment.php?attachmentid=53971&stc=1&d=1355635814[/PLAIN]
How do you go from \displaystyle\ \frac{6}{x^3}\left( 1+\frac{3}{x}+\frac{2}{x^2}\right)\ to \displaystyle\ \frac{6}{x^4}\left( 1+\frac{1}{x}\right)\left( 1+\frac{2}{x}\right)\ ?
\displaystyle\ 1+\frac{3}{x}+\frac{2}{x^2}=\left( 1+\frac{1}{x}\right)\left( 1+\frac{2}{x}\right)\ .
Does this make sense?
\[<br /> \begin{array}{l}<br /> y&#039; = 3(1 + {\textstyle{1 \over x}})^2 x^{ - 2} ( - 1) \\ <br /> = \frac{{ - 3(1 + {\textstyle{1 \over x}})^2 }}{{x^2 }} \\ <br /> \end{array}<br /> \]<br />
Next you would use quotient rule to find the next derivative (second derivative).
Hmm, I probalby did a silly mistake, but I multiplied by x^2
(\frac{6}{x^3})(\frac{x^2 +3x + 2}{x^2}) = (\frac{6}{x^3})(\frac{(x+1)(x+1)}{x^2}) to ... ahhh found my silly mistake - .. of course I need (x)(x), and then x can be canceled - haha..
Thank you very much for you help.
Personally, I'd just expand the binomial then differentiate twice. Keep the exponents as negative powers, it makes everything quicker.
That certainly makes it much easier. I guess I didnt think of that since I was doing problems related to the chain rule. Thank you for your suggestion.
