Solve High School Physics Midterm Problem Involving Pulley & Masses
  • Thread starter Thread starter Whitebread
The discussion revolves around solving a high school physics problem involving a pulley system with two masses. The equations of motion for the blocks and the pulley are established, highlighting that the tensions in the string (T(1) and T(2)) differ due to the need to generate torque for the pulley. It is clarified that while the acceleration of both blocks is the same, the difference in tension is essential for the pulley to rotate. The importance of free body diagrams is emphasized to relate the tensions to the acceleration. Understanding these concepts is crucial for grasping the dynamics of the system.
Whitebread
I'm studying for a high school physics midterm and I need some help here. The question involves 2 masses and a pulley.
A pulley of mas 3m and radius r is mounted on a frictionless bearing supported by a stand of mass 4m. I=(3/2)mr^2 Passing over the pulley is a massless cord supporting a block of mass m on the left and a block of mass 2m on the right. The cord does not slip.
A) Write the following
i. The equations of translational motion for each of the two blocks
ii. The analogous equation for the rotational motion of the pulley
Now, I have the answers, but I do not understand how collegeboard arrived at these answers, and I'm tired of pondering.
T(1)=tension in string over mass "m"
T(2)=tension in string over mass "2m"
i T(1) - mg = ma
2mg - T(2) = 2ma
ii I(alpha) = (T(2)-T(1))r
Can someone explain how these answers were arrived at?
Also, when 2 objects, of different mass, are hanging like this, the tension in the string is uniform, how can T(2) be different from T(1)?
Think of the "net tension" exerted on the wheel as a torque- it is what is causing the pulley to begin spinning.
Alright, I'll try again.
Why are then tensions on the 2 blocks different?
because they have to rotate the wheel, so there must be a difference in the tensions
Yes, I recently had a question on a final involve a pulley with 2 block on either side of it, where T1 was not equal to T2, for the reason of the pulley.
The one thing that is constant between them is the acceleration of the two blocks, however. Therefore, the tangential acceleration of the pulley, given a radius you can find alpha. When you draw free body diagrams, include the pulley, then you can relate T1 and T2 to a.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
