Problem With Columns: Finding Load for Buckling
  • Thread starter BusyEarning
  • Tags
    Columns
In summary, the conversation discusses a student's question about finding the load that will cause a hollow column made of structural steel to buckle. The student initially uses the formula for axial stress, but is advised to do further research as this formula is not applicable for determining critical load. The correct formula is F_{c} = \pi^{2}EI/L^{2}_{e}, where F_{c} represents the critical load, σ_{c} is the critical buckling stress, A is the area of the column, E is the modulus of elasticity, I is the second moment of area, and L_{e} is the effective length of the column. The conversation concludes with the student expressing their struggle with mathematics and receiving encouragement to continue
BusyEarning
Hi every body this is my first post on these forums.
I have a hollow column made from structural steel that has a Young's modulus of 200GN m^-2 and a yield stress of 140MN m^-2 it is 10m long. the larger radius R is 40mm the smaller r is 30mm
I am asked to find the load that will cause it to buckle which i have used the formula
stress = force/cross sectional area
and transposed it to
force = stress x cross sectional area
so
force = (140 x 10^6 ) x (2.199 x 10^-3) = 307.86 x 10^3 N
then the next question asks me to do the same but for a column of half the length ... but if i do this the answer will just be the same because the equation for stress does not take the length into account.
So i think i am doing something wrong in the first part of the question as well, otherwise the next part seems pointless.
I am not brilliant at mathematics so any help hints or advice would be appreciated. thanks in advance.
You are just manipulating the formula for axial stress, which is not the same as the formula which determines the critical load to cause the column to buckle. Do some more research in your notes and try again.
Hint: the column will buckle before the yield stress of the material is reached.
Hi thank you for your help i think i have got it now , i was getting confused as in my textbook it shows this.
F[itex]_{c}[/itex] = σ[itex]_{c}[/itex] A = [itex]\pi[/itex][itex]^{2}[/itex]EI[itex]/[/itex]L[itex]^{2}_{e}[/itex]
Which if someone can explain what this means because the formulas to me are not equal eg.
to me this is like A = B = C
thus A = C ? or am i missing something.
You just need to know what each variable means:
I'll take a stab at it -
σ[itex]_{c}[/itex] - critical buckling stress
A - area of the cross section of the column
F[itex]_{c}[/itex] - critical load above which the column buckles
All the first part of the equation, F[itex]_{c}[/itex] = σ[itex]_{c}[/itex]A,
is saying is that the critical buckling load is equal to the critical buckling stress multiplied by the area of the column, which you already knew from the OP.
The meat of the equation is that F[itex]_{c}[/itex] = [itex]\pi[/itex][itex]^{2}[/itex]EI[itex]/[/itex]L[itex]^{2}_{e}[/itex]
E - modulus of elasticity of the material of the column
I - second moment of area of the column cross section
L[itex]_{e}[/itex] - effective length of the column
A note here: L[itex]_{e}[/itex], the effective length of the column, depends on how the ends of the column are supported.
https://www.efunda.com/formulae/solid_mechanics/columns/columns.cfm
The table at the bottom of the link above gives values of effective length for different end conditions.
Thank you again , I have thrown myself into the deep end i think here , I am Doing HND Electrical Engineering by distance learning and i have been out of education for 10yrs+ so i think i have forgotten all the rules of mathematics lol
Well, give your original problem another try now that you have better info to work with.
1. What is buckling in columns?
Buckling is a phenomenon that occurs when a slender column is subjected to compressive forces, causing it to suddenly bend or collapse. It is a critical failure mode for columns and can lead to serious structural damage.
2. How is the load for buckling determined?
The load for buckling is determined by using the Euler buckling equation, which takes into account the column's length, cross-sectional area, and material properties. This equation calculates the critical load at which buckling will occur.
3. What factors can affect the load for buckling?
The load for buckling can be influenced by several factors, including the material properties of the column, the column's length, the cross-sectional area, the type of end supports, and the magnitude and direction of the applied forces.
4. How can buckling be prevented?
Buckling can be prevented by using appropriate design and construction techniques. This includes selecting the right material and cross-sectional shape for the column, providing adequate bracing and supports, and following building codes and standards for column design.
5. Can buckling occur in all types of columns?
No, buckling is typically observed in slender columns with a high aspect ratio (length-to-diameter ratio). Short and stocky columns are less susceptible to buckling and are more likely to fail due to crushing or yielding.
26K
