Why does the velocity fluctuate before gradually slowing down?
  • Thread starter Thread starter deaninator
    Velocity
The experiment with shake and go cars revealed that the velocity fluctuates rather than consistently increasing, with measurements showing variations at short time intervals. Possible explanations for this fluctuation include inconsistent surface roughness and variable power output from the motor. The data suggests that the velocities are relatively close, indicating that external conditions may affect the results. The discussion emphasizes the need for reasonable justifications for these fluctuations rather than absolute certainty. Understanding these factors can help in analyzing the car's performance over time.
deaninator
Ok my group and I did an experiment relating to shake and go cars. I made an hypothesis that as time (seconds) goes on, then the car's velocity would go up gradually and then would slow down gradually. However though our data proved that as the time goes by, the velocity of the car doesn't simply go up. For example at 4.3 sec the velocity was 0.709 m/s. Then at 4.33 seconds the velocity was 0.714 m/s but at 4.4 sec the velocity was 0.696 m/s. And at 4.433 sec the velocity was 0.729. Why does the velocity fluctuate before gradually slowing down and how can I prove this?
The shake and go car we used:
http://www.fisher-price.com/fp.aspx?st=4040&e=shakengoproduct&pcat=shakengo_racers&pid=32741
How are you calculating these velocities?
A motion detector.
There are several possible explanations. Did the surface that the can ran on have equal roughness? Maybe the motor wasn't producing consistent power (I'm using the term "power" loosely here)?
The conditions certainly weren't ideal so you can't pinpoint with absolute uncertainty as to why the velocity fluctuates. Plus the velocities seem pretty close to each other (within a given range).
Well yeah I don't have to be exact, I just some reasonable reasons why i did fluctuate. Now I just need to prove these reasons.
