Prof's Bonus Question for XRay Diffraction
  • Thread starter Thread starter NeedPhysHelp8
    Diffraction Xray
NeedPhysHelp8
Hi guys, so here's a bonus question on my assignment for materials course.
" A metallic crystal is irradiated with Xrays of a fixed wavelength. Bragg reflection is observed at angles of 23 and 73.5 degrees, as well as another angle phi which is intermediate between the above two values. Assuming the same set of crystal planes (separation d) are responsible for scattering in all three cases, calculate a possible value of phi in degrees. Are there other possible values for phi apart from the value that you found?
<br /> 2dsin(\theta)= m \lambda<br />
i think this is the only equation we need for Bragg peaks because we didn't learn anything else
k so i figured if the wavelenth, distance are constant then only m and \theta are changing so i got:
<br /> m1 = 2dsin23/ \lambda = 0.781 d/ \lamda <br /> and
m2= 2dsin73.5/ \lambda = 1.918 d/ \lambda<br />
I have absolutely no clue how to go from here? any help is much appreciated
The complete solution was deleted (it's not allowed). So if you didn't see it:
You can get m_1 / m_2 from the two last equations.
Then you should select a pair of integers which fit this ratio.
Any integer number between them will give you \varphi.
Ok thanks i'll give that a try, and no I didn't see the complete solution. I'll report back when I get it
so here's what i got:
<br /> \frac{m_{1}}{m_{2}} = 0.407<br />
from here I concluded that that ratio is approximately m_{1} = 2 and m_{2} = 5
so the possible values for m_{\phi}= 3 and 4
Then using m_{1}=2 I plugged that back into first equation above and got \frac{d}{\lambda} = 2.56 so \frac{\lambda}{d} = 0.391
So using m_{\phi}= 3 I got \phi = 35.9 and using m_{\phi}= 4 I got \phi = 51.4
And these values work great! Thanks alot
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
