Projectile motion at an angle problem
A ball is thrown at a 40-degree angle with an initial velocity of 28 m/s, and the problem seeks to determine the horizontal distance it travels before hitting the ground. The vertical component of the initial velocity (Vyo) is calculated as 18 m/s, and the horizontal component (Vxo) is 21.4 m/s. The total time of flight can be found using the equation Ttotal = (2Vyo)/g, where g is the acceleration due to gravity. The horizontal distance can then be calculated using the formula X = Vi*t + (1/2)At^2, where A is zero for horizontal motion. Clarification on the next steps and equations is requested to resolve the confusion.
Anton338
A ball is thrown at a 40 degree angle from the horizontal over level ground. If the initial velocity of the ball is 28 meters per second, how far does the ball travel before hitting the ground?
X=Vi*t+(1/2)At^2
Ttotal=(2Vyo)/g
sine/cosine/tangent
A^2+B^2=C^2
Vyo = 18m/s because Sin(40)*28
Vxo = 21.4m/s because Cos(40)*28
aaand I'm stuck. What do I need? Where do I go?
SO CONFUSED :P
Thanks Forum
