(projectile motion) calculation problem
A projectile motion problem involves a ball thrown from an inclined plane, with calculations focused on finding the length OA and its maximum value. Initial calculations using kinematic equations led to an expression for time and distance, but discrepancies arose when comparing results with the provided answer. Participants discussed the need for trigonometric identities to reconcile differences and derive the correct formula for OA. An alternative approach was suggested, involving the use of axes aligned with the incline and applying kinematics. The conversation highlights the complexity of projectile motion on inclined planes and the importance of precise calculations.
asdf1
Question: A ball with a velocity of Vo is thrown from the bottom of an inclined plane (point O) with an angle of \phi. The inclined plane has an angle oftheta . The ball lands on top of the inclined plane on a point A. Find the length of OA and its maximum value.
My calculations:
1. x = V_{0}\cos (\phi) t
2. y=Vo*sin\phit -0.5*gt^2
3. y=xtan\theta
From the above equations, I got t=[2Vo*sin(\phi-\theta)/[gcos\theta]
So OA= xsec\theta
=Vo*cos\phi*sec\theta/(gcos\theta)
But the answer is
OA= Vo^2*[sin(2\phi-\theta)-sin\theta]/[gcos^2(\theta)]
And I don't know how to tell from my calculations what the max value is, and why it's different from the answer...
Can somebody help?
http://img97.imageshack.us/my.php?image=inclinedplanesu8.png"
Change your tags to [ tex ] ... [ /tex ] (without the spaces obviously) :wink:
Click on this equation below to see how it is coded;
thanks for teaching me latex! ^_^
3. y=xtan\theta
How did you arrive at this? Would you mind posting your steps?
from 1. and 3. ->
y=V_{0}\cos (\phi) t*tan\theta
then take the above result and plug it into 2. getting:
y=Vo*sin\phit -0.5*gt^2=V_{0}\cos (\phi) t*tan\theta
Rearranging the equation and using the formula
sin2\phi=2sin\phicos\phi to simplfy the equation makes the result for
So OA= xsec\theta
Up to this point, everything is fine.
asdf1 said:
OA=Vo*cos\phi*sec\theta/(gcos\theta)
You seem to have made an error here. What is the expression for x?
Sorry! I mistyped!
It should be
OA= Vo*cos\phi*2Vo*sin(\phi-\theta)*sec\phi/[gcos\phi]
Do you mean OA= Vo*cos\phi*2Vo*sin(\phi-\theta)*sec\theta/[gcos\theta]?
If yes, then you are on the right track. Compare your answer with the one given in the book. What is the last step you need to take?
Yes...
I think that I have to use some kind of trignometric formula to get the answer in the book?
the ans should come out to be
R=(2u<sq (only u)>sin<sq>(a-b)cos<sq>a)/(gcosb)<sq>
the max value will be when a= 45-b/2
where a = angle of projection + angle of inclination(b)
angle of inclination=b
if u ask i will mail u the proof
A Better solution
Hello
well i have written a different solution
i am taking axis along the incline and perpendicular to the incline then taking components of g(acceleration due to gravity) along and perpendicular to the incline and then applying kinematics equations
anywayshttp://helpjee.blogspot.com/2006/08/inclined-plane-problem_01.html"
bye
:smile: :smile:
Wow! thank you for the different approach!
