Projectile Motion Problems: Calculating Maximum Angles and Heights
The discussion focuses on solving various projectile motion problems, including finding maximum angles of projection and calculating heights and velocities at specific points. Participants express confusion about the mathematical approaches required, particularly in deriving equations for motion and understanding the relationships between angles, velocities, and forces. Key points include the need to differentiate position equations to determine conditions for increasing distance from the origin and the importance of correctly applying trigonometric identities in solving for angles of inclination. The conversation highlights the challenges of applying theoretical concepts to practical problems, emphasizing the necessity for clarity in algebraic manipulation and understanding of physical principles. Overall, the thread illustrates the complexities of projectile motion analysis and the collaborative effort to clarify these concepts.
hancyu
1. Find the maximum angle of projection of a projectile such that its position vector from the origin to the subsequent position of the projectile is always increasing.
2. Consider two masses at either end of a frictionless pulley. The first block of mass 10kg sits on a inclined plane while the other block of mass 5kg hangs on the other end of the pulley. The coefficient of kinetic friction between the plane and the block is 0.2. Find the angle of inclination of the plane if the masses are to move with constant velocity.
3. Find the angle of projection of a projectile if its horizontal range will be equal to the magnitude of the maximum height reached.
4. A projectile is launched at an angle of (degrees)40 with an initial velocity of 25m/s when upon traveling 22m horizontally it strikes a wall. Find the height and velocity of the projectile when it hits the wall.
i don't know how to do all these...
i'm clueless.
Yep, ur clueless. Pick one of these problems and TRY to do something with it. Anything. Then someone can help you.
im trying to solve number4
this is what i got...
Vxo= 25cos40 = 19.15m/s
Vyo= 25sin40 = 16.07m/s
tx=ty= (Vyo)/(9.8) = 1.64s
thus, a = (Vxo)/(1.64) = 11.68m/s^2
using x=Vxot +1/2at^2...
x=47.11
im lost...
Good! You got the initial velocities ok. From there you don't derive the acceleration. The acceleration is given, it's just gravity -9.8m/sec in the y direction. So there is no acceleration in the x direction:
x(t)=v0x*t
And in the y direction:
y(t)=v0y*t+(1/2)*g*t^2
Use one of those equations to find the time it hits the wall. Which one? It's 22m HORIZONTALLY away.
**EDIT**
so... 22/19.15 = t = 1.15s
y=Vyot +1/2gt^2
y=12.0m
vyf^2 - vyo^2 = 2gy
vyf=4.8m/s
is this right?
help on the first problem please. i really don't get the question.
x=47.11
y=13.18
22m/(47.11/2) = 93%
y*93% = 12.26m = h
2(12.26)(-9.8) - 16.07^2 = -Vyf^2
Vyf = 22.32 m/s
is this right?
That's AWFUL. It doesn't make any sense at all. Why did you ignore what I wrote? I thought you wanted help.
sorry...i was trying to solve and did not notice that you posted a new msg.
^^ i edited that part. i tried solving without the (b)a(/b)
hancyu said:
**EDIT**
y=Vyot +1/2gt^2
y=12.0m
vyf^2 - vyo^2 = 2gy
vyf=4.8m/s
is this right?
That's it. Good.
If you throw a ball upwards at a steep angle it will go away from you and then come back towards you (and hit you on the head if the angle is too steep). If you throw it out at a shallow angle then it always travels away from you and doesn't come back. They want you to find the angle that divides the two cases.
okayyy... so if angle=0 range =0...
angle=45 range = maximum...
then...
problem #2
g*[(5-10cosO)/(5+10)] = 0
a=0 because its' velocity is constant. ryt?
then... angle should be...60degrees?
then...
No, it's not 45 degrees. If the launch angle is theta then you work out x(t) and y(t). The distance squared from the launch point (0,0) is r(t)^2=x(t)^2+y(t)^2. You want to take the derivative of r(t)^2 with respect to t and then figure out for which angles theta that expression has a zero derivative. These are the ones where it comes back towards you.
hancyu said:
problem #2
Yes, the forces balance because a=0. You might want to write out explicitly what the forces acting on the mass on the incline are. You've left out the kinetic friction.
so...
T-m = ma
T-10cosOg + 10cosO(.2) = -ma
mg+mcosOg +10cos(.2)=(ma +ma)
then... g(m +mcosO) + 10cosO(.2)=a(m+m)
how will i get O?
i really don't get this.sorry:confused:
is this anything like.
y=yo+Vyot +1/2gt^2
x=xo+Vxot+1/2gt^2
then u get: (y-x)/(Vyo - Vxo) = t
hancyu said:
so...
T-m = ma
how will i get O?
I don't understand how you are getting these funny equations. Could you explain in addition to just writing a bunch of stuff down? The mg force down the incline should be related to sin(O). The frictional force should be related to the normal force which involves cos(O). You should have both in the equation.
the forces acting on mass=5kg is...tension and gravity ryt...
so, T- mg= ma
then, the forces acting on mass=10kg is tension, gravitational force,frictional force
so, T-mgcosOg - ________ + mcosO(.2)= -ma
how do i get normal force?
so, T- mg= ma
Ok, you've got the forces names right. T is 5kg*g. O is the angle the incline makes with the horizontal, yes? I would say the component of the weight down the incline is mgsin(O), and yes, the frictional force is mgcos(O)*(.2). That just comes from splitting the weight force up into parts tangential to the incline and normal to it. a=0. You keep writing down stuff that is halfway correct, but I get the feeling you really don't understand it, because of stuff that might just by typos. Like "mgcosOg" has two g's in it. "mcosO(.2)" doesn't have any. How can that be, they are both dimensionally wrong. One of the trig functions is wrong. And there is nothing to put in the blank space. Are you sure you shouldn't be warming up on some easier questions?
these questions are for extra credit(which i badly need.so, they shoudnt be as easy as cake.)
so, T-mg=0 and T-mgcosO +mgcosO(.2)=0
is that right?
^^ i mean... T-mgsinO + mgcosO(.2) = 0
Extra credit, that explains it. Does that seem right to you? Is the magnitude of every force correct? Do they point in the right direction? .... Yes, it's right.
so...i equated both of them to each other. i got
-5g = -10gsinO + 10(.2)gcosO
then what?
First cancel g. Now all that you don't know are sin(O) and cos(O). Is there a relation between sin and cos you can use to get rid of one of them?
there's tangent which is equal to sinO/cosO. is that it?
That would work if the -5 weren't there. No, I want a RELATION between sin and cos. They aren't independent.
uhm...sin(90-O) = cosO or cos(90-O)= sinO
True. But that doesn't make it any easier to solve. How about sin(O)^2+cos(O)^2=1. Or sin(O)=sqrt(1-cos(O)^2).
  • #31
i don't get it... so, should i substitute sinO with (1-cosO^2)^1/2 ?
  • #32
i think theta should be 40.7(degrees)
i got it through trial and error. i just don't know how to solve for it.
  • #33
Good job on getting the approximation. Write the equation as 10*sin(O)-5=2*cos(O). Now put cos(O)=sqrt(1-sin(O)^2). Now square both sides. You get a quadratic in sin(O). Solve for sin(O). Since you squared both sides check that each of your answers actually satisfy the original equation. Now find O.
  • #34
so 1st i divided the whole equation with -5
i got.
1=2sinO -cosO then, i substituted sqrt(1-sin(O)^2) to cosO
then i got. 1=4sin^2(O) + 1 - sin^2(O) which doesn't make sense.
how should i do it?
  • #35
i got.
how should i do it?
You aren't doing the algebra right. If you square 2sinO-cosO you get 4sin^2(O)+cos^2(O)-4*sin(O)*cos(O). There's a cross term you've forgotten and you haven't gotten rid of the square root at all. Get the sqrt part all by itself before you square.
  • #36
let sinO be x
so its. (2x-1)^2 = 1-x^2
5x^2 - 4x = 0
sin^-1 of .8 = 50+
which is not equal to 40.7(which is a close approximate)
how should i do it
  • #37
let sinO be x
5x^2 - 4x = 0
sin^-1 of .8 = 50+
how should i do it
  • #38
You've got the equation wrong now. It's 10*sin(O)-5=2*cos(O). You goofed it up way back when you divided everything by 5. About half your problem is simple sloppiness.
  • #39
i got it! 104sin^2(O) - 100sin(O) +21 = 0
then O should be 18.05 and 40.7
^^ both satisfies the equations above.
  • #40
I don't think 18.05 works as well. You should check that. But look, if you pay attention and check what you are doing you can solve these problems.
  • #41
hancyu said:
**EDIT**
y=Vyot +1/2gt^2
y=12.0m
vyf^2 - vyo^2 = 2gy
vyf=4.8m/s
is this right?
if the teacher's asking for Vf... how do i get it. since 4.8m/s is Vyf ryt? and Vxf is 19.15. should i use pythagorean theory thinggy?
  • #42
Sure, if you want the total magnitude of the final velocity, use the pythagorean thingy.
  • #43
help on the first question please. i still can't understand it.
  • #44
Start by rereading post 11. Then tell me what you don't understand.
  • #45
shouldn't there be 2 angles. coz it will be lyk...'between angle1 & angle2 '
  • #46
No. Lyk, coz it will b shallow angle always out, steep angle always starts coming back. There is an angle A such that a<A it will go out, a>A it will come back. Why two angles?
  • #47
^you said on one of your posts that r(t)^2=x(t)^2+y(t)^2
is that the same with R^2= cos^2 (t)+ sin^2 (t)
what should i multiply cos and sin with?
  • #48
No. Do this the same way you did the other problems. x(t)=v*cos(A), y(t)=v*sin(A)-(1/2)gt^2. v is the initial velocity, A is the angle from the horizontal. Yes, r(t)^2=x(t)^2+y(t)^2. You have to figure out a condition on r(t)^2 that will insure it's always increasing. I.e. (r(t)^2)' is always positive. I.e. (r(t)^2)' is never zero. I've mentioned before that this is not an easy problem. Are you sure you need the extra credit that much?
  • #49
yes. i really need extra credit that bad.
Vo is not stated in the problem...what should i do?
R is range ryt? then x(t) is the x component and y(t) is the y component?
  • #50
Leave Vo unknown. It doesn't matter. It will cancel out. Yes, x(t) and y(t) are the components. I don't know what R is. r(t) is the distance from you to the projectile at time t.
