Projectile motion question totally stuck
The discussion revolves around determining the optimal angle for a cannon to fire projectiles up a hill with an elevation angle alpha to achieve maximum range. Participants suggest separating the initial velocity into horizontal and vertical components and using projectile motion equations, while also considering the hill's slope as a linear equation. The conversation highlights the complexity of the problem, as the optimal angle is not simply 45 degrees due to the incline. There is a focus on deriving equations and solving for the angle theta that maximizes the range, with various algebraic manipulations discussed. Ultimately, the participants are working collaboratively to clarify their approaches and resolve misunderstandings in their calculations.
emyt
A cannon is arrange to fire projectiles, with initial speed V0, directly up the face of a hill of elevation angle alpha. At what angle from the horizontal should the cannon be aimed to obtain the maximum possible range R up the face of the hill?
v = v0 + at?
x = x0 + v0t + at^2 ?
I have no idea what to do, please help my self esteem is totally shot .. I can't believe that I actually have no clue
Just begin as you would any projectile problem.
Separate the initial velocity into horizontal and vertical parts. Then write two headings:
Horizontal and Vertical. Decide in each case whether you have constant speed or accelerated motion and write the appropriate formula(s).
You'll need some model for the hill - it is like a straight line on a y vs x graph so you know its equation.
Hi, thanks for the reply - I tried doing something like..
Vx0 = V0costheta
Vy0 = V0sintheta
Rsinalpha = V0sintheta - 1/2gt^2
Rcosalpha = V0costheta
thanks a lot
Vx0 = V0costheta
Vy0 = V0sintheta
but this didn't get me anywhere.. are you telling me to treat the hill as if it were a flat surface? what do I do with the angle the hill makes then?
thanks a lot
Realign your coordinate system so that the positive x-axis is pointed up the slope. The angle of the slope comes into play when you calculate the accelerations in the x and y axes.
can I just consider the hill as a straight line, calculate the angle from there and then just add on alpha after? I thought of this but I wasn't sure..
thanks
Isn't the max for any equation 45 degrees
45 degrees is the optimum angle to maximize the range on a flat surface. Throwing up a hill at angle alpha, the optimum angle will vary with alpha.
emyt, I was thinking that a hill of angle alpha will have a slope of tan(alpha) so its equation will be y = mx = tan(alpha)*x. [1]
For the horizontal part, constant speed, you'll have something like
x = v*cos(θ)*t [2]
For the vertical part, instead of "Rsinalpha = V0sintheta - 1/2gt^2 " I would just write y = v*sin(θ)*t - 1/2gt^2 in this notation. [3]
Sub [1] into [2] or [3] so you are looking at the situation when the projectile hits the hill. Study the remaining two equations and see if you can see what angle gives the maximum x or y that you are looking for.
x = v*cos(θ)*t [2]
hi, thanks for the reply:
I thought that I was looking for rcosalpha and rsinalpha as my final x and y.. since those would be the coordinates at the end of the range?
thanks
Oh, I see it now! I was confused at the lack of x's and y's. You are saying the same thing I did and you have already got it down to two equations. Missing a couple of t's, though. It's x = v*t and
y = v*t + .5*a*t^2.
If you solve the easier one for t and sub in the other, you get a nice quadratic in r so you should be able to get its maximum either using a derivative or recalling a quadratic's max from high school math.
well, to find a max range
cant we use R=u2sin2\theta/g
y = v*t + .5*a*t^2.
yeah I got it, thanks - I was repulsed by the hideous substituting... it wasn't so bad
thanks again
That's a powerful little formula, look416!
But it is only for shooting on a horizontal surface and doesn't apply to this problem.
Congrats, emyt!
hi, I tried putting -4.9(rcosalpha/V0x costheta)^2 + v0sintheta(rcosalpha/V0x costheta) - Rsinalpha = 0 into the quadratic formula and it got really messy :S should I be doing it like this? there are too many unknowns..
thank you
oh i got it
thx for clearing my confusion
I didn't get such a messy quadratic as you. Mine had no c term so I could common factor it. However, I ended up with a formula for tan θ that blows up when alpha equals zero, so I must have an error.
Perhaps if we work together on it we can find each other's errors.
You are supposed to take the lead. How about we use A for alpha and T for theta so it isn't quite so messy? Do you have
r*cos(A) = v*cos(T)*t and r*sin(A) = V*sin(T)*t - .5*g*t^2
as the starting point? What did you get next?
hi, I had the same thing, when I solved for t I got rcos(A)/vcos(T)
then I plugged it into the sin equation and subtracted V*sin(T) from both sides to equate it to zero so I could find rcos(A)/vcos(T) and I thought that if I could assign a number to that, I could solve for theta.. but it didn't work
thanks for working with me
Okay so putting t = rcos(A)/vcos(T) into r*sin(A) = V*sin(T)*t - .5*g*t^2
gives you
r*sin(A) = V*sin(T)*rcos(A)/vcos(T) - .5*g*r^2/v^2*cos^2(A)/cos^2(T)
Why now subtract V*sin(T) from both sides? Suggest we divide both sides by r and take the two terms that have no r to the left side.
This is fun - let's keep going!
gives you
I equated it to zero so I could try solving for rcos(A)/vcos(T), but I guess I could divide by r as well, I just thought it would work with that method from what you said before
thanks I'm on it
gives you
hi, what did you get? :S I'm doing so much expanding and whatnot it doesn't seem right
sin(A) = V*sin(T)*cos(A)/vcos(T) - .5*g*r/v^2*cos^2(A)/cos^2(T)
after dividing by r.
I'll take the r term to the left and the sin(A) to the right:
.5*g*r/v^2*cos^2(A)/cos^2(T) = V*sin(T)*cos(A)/vcos(T) - sin(A)
How would you solve that for r?
oh right, thanks.. then you divide and multiply to isolate r..
r = (V*sin(T)*cos(A)/vcos(T) - sin(A)*[v^2*cos^2(A)/cos^2(T)])/.5*g
but V theta and alpha are all unknown?
We must consider that alpha (A) is known - the specified hill angle.
Our job is to find the theta that makes r a maximum.
To avoid the mistake I made last time, we should check at this stage to see if it makes sense when alpha is zero.
If you rotate your coordinate plane (I believe):
x = vocos(\theta - \alpha ) t - \frac{1}{2}gsin\alpha t^2
y = vosin(\theta - \alpha) t -\frac{1}{2}gcos\alpha t^2If you don't rotate your coordinate plane:
x = vocos\theta t
y = vosin\theta t - \frac{1}{2}gt^2
tan \alpha = \frac{y}{x}
R = \sqrt{x^2+y^2}\theta = Launch angle
\alpha = Angle of incline
Thanks, Jebus. Regret I don't understand your very first step, the
v*cos(theta)*t. It seems to me that after you rotate, your v would no longer be v but something like v*cos(alpha).
emyt, I'm not agreeing with your last step. I get
.5*g*r = V^2*sin(T)*cos^3(A)/cos^3(T) - v^2*sin(A)*cos^2(A)/cos^2(T)
and then
r = 2/g*V^2*sin(T)*cos^3(A)/cos^3(T) - 2/g*v^2*sin(A)*cos^2(A)/cos^2(T)
I probably should've stated the variables. I'll edit that in :>
x = vocos\theta t
hi, if I don't rotate the coordinate plane, wouldn't x and y be Rcosalpha and Rsinalpha?
and I see how you get v0cos(theta - alpha) but how did you get gsinalphat^2 .. etc ?
thanks
and then
I think if you do the algebra it works out to be the same thing, I just copied and pasted thing around.. anyway, don';t you think that the answer should have a bit more of a concise method? there's point where I feel like the answer isn't going anywhere...
thanks
Yep. That may require more manipulation of equations in the long run though.
In the rotated coordinates, how do you get the time and x value when it hits the hill?
and then
were you planning to plug that in somewhere? that's humongous
  • #31
Found a mistake.
r = 2v^2/(g*cos^2(A)) times this trig expression:
cos(A)*sin(T)*cos(T) - sin(A)*cos^2(T)
Only this last expression varies with T, so only it matters.
To get the max for r, we differentiate this with respect to T and set it equal to zero. Almost there! I already checked when A=0 and got the 45 degrees we would expect!
Jebut, your rotated solution gets as messy as ours when you set y = 0 to be on the hill, solve for t and sub into the x equation.
  • #32
Delphi51 said:
Found a mistake.
okay, thanks for checking that it works. let me check it out
so you got r to be 2v^2/(g*cos^2(A)) and which equation did you plug it into? either one of the x or y?
thanks a lot
  • #33
Well, if we forgo rotating, I think the best approach here would be to look at these two equations as intersecting curves/lines.
One is the regular quadratic for projectile motion, and the other would be the straight line y=\tan{\alpha}x
Setting the two to be equal, and solving for the x where they intersect will give us the x coordinate of their intersection (And the trivial solution x=0)
Since that's a linear function, maximizing x_{impact} would maximize the whole of the function. All we've got left to do from there is to differentiate with respect to \theta and equate to zero.
Now it's just a question of getting over the algebra.
  • #34
thanks, I was really thinking about the axis rotation.. I don't get why the answer isn't just pi/4 + alpha?
on a straight line, the maximum angle is pi/4 so if you turned the axis, it would be pi/4 + alpha?
  • #35
anybody? I actually think this is a good idea, but where have I gone wrong?
thanks
  • #36
It just isn't that simple. In the rotated system you have accelerated motion in both directions. Consider the case when alpha is 80 degrees. Your answer says shoot at pi/4 + alpha = 45+80 = 125 degrees, which is actually away from the hill and would never hit it.
RoyalCat's idea of using x instead of r seems to reduce the algebra considerably. I worked it through to the end and got the same answer I got last night with the r. Unfortunately there seems to be an error in my work. I get tan(2θ) = - 1/tan(alpha) with a condition alpha not equal to zero. So when alpha is 10 degrees, it says shoot at -40 degrees.
Edit: I used a spreadsheet to take a good look at my solution
x = 2*v^2/g(sinθcosθ-tanα*cosθcosθ)
before taking the derivative to get the max, and it works. With alpha 10 degrees, shooting at 48 degrees gives the max range. So I just have an error in the derivative or last bit of algebra.
Recommend you use y = tan(alpha)*x to eliminate y in the original equation y = v*sinθ*t -.5*g*t^2 and use x = v*cosθ*t to eliminate t. Solve for x. About 3 lines on you'll see my x = expression above.
  • #37
thanks for replying, I get the idea behind RoyalCat's idea, I think it's nice. I'm not incredibly familiar with the applications of calculus yet so I need some time before I can intuitively use them freely.. I'd like to try solving it with the rotational method though because it seems like an interesting route, I see what you mean about the acceleration though, I'll see how I can fix it
thanks guys
  • #38
how did you get x = Vcos(T-A) - 1/2g cos(A) t^2? the -1/2gcos(A) part I mean I would think that the acceleration in my new axes would be a vector that is a sum of two multiples of vectors going along the new x and y axis?
thanks
  • #39
Mystery solved on the tan(2θ) = - 1/tan(alpha).
When alpha = 10 degrees, you get 2θ = -80 degrees OR 100 degrees.
I should have ignored the negative solution!
So θ = 50 degrees. Shoot at 50 degrees to maximize range on the 10 degree hill.
  • #40
yes, that is correct - the book says pi/4 + alpha/2
anyway, could you please shed some light on the rotating axis method? how come you have to multiply -1/2g by cos(A)?
x = V*cos(T - A) - 1/2gcos(A)t^2?
thanks
  • #41
If you call the axis along the inclined plane to be x axis, the velocity makes an angle ( θ-α).
The time of flight T = 2*v*sin( θ-α)/g*cosα.
Horizontal distance x' = v*cosθ*Τ = 2v^2*sin(θ-α)*cosθ/gcosα
R' = x'/cosα = 2v^2*sin(θ-α)*cosθ/gcos^2(α)
= [2v^2/g*cos^2(α)]*1/2[sin(2θ-α) - sinα]
The range R' on the inclined plane will be maximum when 2θ - α = π/2. Or
θ = π/4 + α/2.
  • #42
θ = π/4 + α/2.
thanks, but could you tell me why you multiplied the acceleration by cos alpha?
  • #43
If you rotate the axis, you have to change the acceleration. Because in projectile motion the acceleration is perpendicular to x-axis. So gcosα is perpendicular to the new x-axis.
  • #44
hi, thanks.. but why how did you know to use gcosa? I would think that you should take |a| multiplied by some unit vector along the direction? but cosa is just some scalar, how does that work?
thanks
  • #45
Because you have rotated the original axis to new axis through an angle α, you have to take the component of g in that direction to study the motion of the projectile with respect to the new axis.
  • #46
okay.. I think I'm starting to see it.. the x component of the acceleration vector gravity in the new axis is parallel to sin alpha and the y component is parallel to cos alpha.. multiplying it by g gives you the magnitude of gravity...
man, I need to get a new textbook, NONE of this is in my textbook.
thanks
  • #47
thanks
is this right?
thanks
  • #48
θ = π/4 + α/2.
never mind, I'm just trying to figure the rest out now.. I don't know why you did x'/cosa
  • #49
V*costheta*T is the horizontal distance. The range he is using in the rotated coordinates is the distance along the hill.
θ = π/4 + α/2 is such a nice solution! After seeing it I figured out how to get it from my tan(2θ) = -1/tan(α) = -sin(α)/cos(α)
tan(2θ) = -sin(π/2+α)/-cos(π/2+α) = tan(π/2+α)
so 2θ = π/2+α and θ = π/4+α/2.
Pretty tricky trigonometry in the unrotated coordinates.
I didn't work the rotated on all the way through to see if it is easier.
  • #50
how do you get the distance along the hill by x'/cosa?
