Calculation of Horizontal Velocity, Initial Vertical Speed
To calculate horizontal velocity, initial vertical speed, angular launch speed, launch angle, and maximum height for a 7.3g object projected 24.5m, basic equations of motion are essential. The formulas include V=d/t for average velocity and the kinematic equations for motion analysis. It's important to assume no air resistance, which allows horizontal velocity to remain constant. Applying these equations to both vertical and horizontal components will yield the desired results. Properly using the variables in the formulas is crucial for accurate calculations.
H3lpPlz
Calculate any or all of the following: horizontal velocity, initial vertical speed, angular launch speed, launch angle, and maximum height all for an object with a mass of 7.3g that is projected 24.5m.
V=d/t V=24.5/7.3 V=15.031
Remember the basic equations of motion for particles like this
<br /> v = u + a t<br />
<br /> s = s_0 + u t + (1/2) a t^2<br />
<br /> v^2 = u^2 + 2 a s<br />
where v is the final velocity, u is the initial velocity, s is the displacement, a the acceleration and t the time.
Also remember that you are going to be assuming no air resistance, so horizontal velocity will remain constant.
Applying these formulae to verticle and horizontal components of the initial velocity should get you all of those
another formula that may come in handy is...
2a∆y=V²-Vo²
where Vo=initial velocity.
since it includes horrizontal motion, be sure to use the right components when pluging in the variables, expecially for velocity. good luck
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
