Flight time of Projectile motion
The discussion centers on calculating the flight time of a projectile thrown at an angle with an initial speed and from a height. The user initially calculated the vertical velocity component but later realized they were using radians instead of degrees on their calculator, which led to incorrect answers. After correcting this mistake, they received assistance in solving the quadratic equation for time of flight. A helpful link to a quadratic calculator was also shared to aid in the calculations. Ultimately, the user expressed gratitude for the guidance that clarified their error.
wassup
Ok, I thought I knew how to do this, but for some reason, according to my homework website, my answer is wrong. So I'm turning to this board before I beat my head against the wall. Please help me.
A ball is thrown with an initial speed of 31 m/s at an angle of 45�. The ball is thrown from a height of 12 m and lands on the ground.
Find the time of flight.
Initial vertical upward velocity = 31 sin 45 = 26.378m/s.
The displacement [Yf – Yo] = –12 m
Yf -Yo = Vot - 0.5*g*t^2
–12 = 26.378 t – 4.905 *t^2
4.905 *t^2 – 26.378 t – 12 = 0
Using b^2 – 4ac = 26.378 ^2– 4*4.905*(– 12)
√ (b^2 – 4ac) = 30.516
– b ±√ (b^2 – 4ac) = 26.378 ± 30.516
= 56.894 leaving the negative time value
Dividing by 2a = 9.81
t = 5.7996 s
Is my work right?
Welcome to PF.
I'd check the vertical velocity component again.
31 * sin45° = ... ?
Ugh, no wonder none of my answers have been right, I've been in radian mode on my calculator. I feel like an idiot. Thank you for pointing out the obvious to me.
