Projectile Problem: Find "d" on 10° Incline
  • Thread starter Thread starter James22
    Projectile
The problem involves calculating a distance "d" on a 10° incline related to projectile motion. The original poster expresses difficulty due to the incline, contrasting it with a simpler horizontal scenario.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss determining horizontal speed and height at impact. There are attempts to relate height and horizontal distance using trigonometric functions and equations of motion.
Some participants have provided guidance on calculating horizontal speed and suggested using equations to relate height and time of flight. Multiple interpretations of the problem setup are being explored, particularly regarding the incline's effect on calculations.
The original poster mentions uncertainty about handling the incline and the implications it has on the projectile's motion. There is also a reference to specific angles and the need for clarity on height calculations.
James22
There is the question I am having trouble with. All the data is given in the image. I am to find "d". The slope being on an angle is what is throwing me off. It would be simple enough if the ground was perfectly horizontal, but I am not sure how to handle the 10 degree incline.
My first thought was to make it as the golf ball was hit horizontally and at an angle of 55 degrees. I am not sure how to figure out the distance "d" though.
Any help would be greatly appriciated
s=volt + 1/2 at^2
v=vo + at
V^2=vo^2 + 2as
I am not sure where to start.
Find the horizontal speed. Determine the height at B. Plug that time into your equation for height: [itex]h = v_yt - .5gt^2[/itex] to find the time of flight. Put that value of t into your equation for horizontal speed.
AM
Thanks for the reply.
I have the horizontal speed as 80cos55 = 45.89ft/s
I am unsure of how to calculate the height at which the ball hits the ground. Could someone shed some light as to how I would go about this.
Thanks in advance.
The height divided by the horizontal distance traveled (vxt) is tan(10).
This equation for h, combined with [itex]h = v_{0y}t -\frac{1}{2}gt^2[/itex] gives you two equations and two unknowns. So you can solve for t.
AM
