Projectile Problem: Find Theta | d=30, v=22, g=9.8, y0=2
  • Thread starter Thread starter rajesh.msen
    Projectile
To solve the projectile problem with given parameters (d=30, v=22, g=9.8, y0=2), the key is to analyze the motion along the x- and y-axes independently. The user is attempting to find the launch angle theta, but is struggling with the equations. A suggested approach involves using the formula for projectile motion on uneven ground, which simplifies the analysis. It is important to break down the problem into horizontal and vertical components to find the correct angle. Understanding these principles will help in determining the required angle for the projectile.
rajesh.msen
Hi to all guys i am not good in physics and trigonometric I tried to do a projectile system.My launch point is higher than target point.I know the velocity v, target_distance d, gravity g,Launch_height_y y0.I added a image that shows the equation.I tried my own but not solved the equation.Please some one help me
d = 30,v = 22 , g = 9.8 ,y0 = 2
I wants to find the theta(angle)
Not sure how you got the equation but ut would be best to analyse along the independent x- and y-axes.One is accelerated and other is simple non-accelerated one.
Of course it is right. What I meant was analysis along x- and y-axes separately is much simpler(that's how they got the formula).
