Proof dealing w/ Simple Harmonic Oscillations
The discussion focuses on proving the period of a simple pendulum performing small oscillations, expressed as T = 2π√(l/g), where l is the pendulum's length and g is the acceleration due to gravity. Participants explore the fundamental equations of oscillation, including the relationships between mass, frequency, and period. The importance of small angle approximations (θ ≤ 5 degrees) is emphasized, as it simplifies the equations involved. Clarifications on the derivation of the equation kl = mg are provided, linking force and displacement in the context of pendulum motion. Overall, the conversation highlights the mathematical relationships and principles governing simple harmonic motion in pendulums.
nix
Prove that the period of a simple pendulum doing small oscillations is equal to:
2(py)x(square root of: l/g)
where py is 3.14..(obviously..lol)... l is length of the string of the pendulum and g is gravity
Also... the pendulum is basically just a ball on a string moving from side to side. and the equations we have been given to solve it is the fundamental eq. of an oscillation:
k = mw^2 = m x(2py^2/T) = m (2(py)f^2)
where f is the frequency, m is the mass, w is omega (the angle), and k is the spring constant and T is period
tricky..eh?
thanks for any help or suggestions..
oops i just read the thing i was supposed to read before posting...
anyways this is what I've done and i don't think it makes sense maybe i should clarify the question with my teacher later..
m(2(py)^2/T) = m(2(py)f^2)
T = m(2(py)^2)/m(2(py)f^2)
T = py/f^2
f = 1/T
T = (py)T^2..maybe I am using the wrong equation...
And another thing about the question is that the angle is less than or equal to 5 degrees...the angle btw the original position of the pendulum and the position of the pendulum when its movind to the side.
T = py/f^2
f = 1/T
First equation has got wrong dimensions whereas second equation is correct.
Equations which might help u are
\omega^2 = \frac{k}{m}
\omega=2\pi f
T=\frac{2\pi}{\omega}
kl=mg
All equations are valid for small angle \theta\leq 5^0
thanks so much for the help with the equations...i got it! yay!
but can you explain to me how kl = mg...
thanks again
That requires u to know the Force equation
i.e. F=-mgsin\theta
for small theta sin\theta = \theta
therefore the equation is F=-m\theta = -\frac{mgx}{l}
displacement along the arc=\theta l
also if u draw a free body diagram fo the forces . u have
k(l+\delta x)=mgcos\theta for small displacement u can assume \delta x=0 & cos\theta=1
so u get kl=mg
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
