Evaluating the Second Term of Integration by Parts for $\delta (x)$
The discussion focuses on demonstrating the relationship x (d(δ(x))/dx) = -δ(x) using integration by parts. The integration involves an arbitrary function f(x) and shows that the boundary term evaluates to zero due to the properties of the Dirac delta function at infinity. The key step is correctly evaluating the second term, leading to the conclusion that the integral simplifies to -f(0). This manipulation confirms the initial assertion regarding the Dirac delta function's behavior. The discussion concludes with a successful resolution of the problem.
Reshma
Show that x \frac{d(\delta (x))}{dx} = -\delta (x)
where \delta (x) is a Dirac delta function.
My work:
Let f(x) be a arbitrary function. Using integration by parts:
\int_{-\infty}^{+\infty}f(x)\left (x \frac{d(\delta (x))}{dx}\right)dx = xf(x)\delta (x)\vert _{-\infty}^{+\infty} - \int_{-\infty}^{+\infty}d\left (\frac{xf(x) \delta (x)}{dx}\right)dx
The first term is zero, since \delta (x) = 0
at -\infty, +\infty.
How is the second term evaluated?
Well, if we are to do this symbol manipulation properly, you should have:
\int_{-\infty}^{\infty}xf(x)\delta{'}dx=xf(x)\delta\mid_{-\infty}^{\infty}-\int_{-\infty}^{\infty}(f(x)+xf'(x))\delta(x)dx=-(f(0)+0*f'(0))=-f(0)
Wow, thanks Arildno! I got it!
