Proof involving vector spaces and linear transformations
The discussion revolves around proving a property of linear transformations in the context of vector spaces. Specifically, the original poster is tasked with showing that for any vector \( v \) in vector space \( V \), the transformation \( T \) satisfies \( T(-v) = -T(v) \). This involves understanding the definitions of additive inverses and the behavior of linear transformations.
  • The original poster attempts to manipulate the equation involving \( T(v) \) and \( T(-v) \) but expresses confusion about the steps and the implications of reaching \( 0 = T(v) + T(-v) \). Some participants suggest clarifying the reasoning behind why \( T(v + (-v)) = 0 \) and emphasize the definition of additive inverses.
Participants are engaging in a constructive dialogue, with some providing hints and guidance on how to approach the proof without giving away complete solutions. There is a recognition of the need for clearer explanations of certain steps, particularly regarding the properties of linear transformations and additive inverses.
There is a mention of whether the original poster is allowed to use certain properties, such as \( 0x = 0 \) for all \( x \), without proof, which indicates potential constraints on the assumptions that can be made in the proof.
killpoppop
1. Suppose V,W are vector spaces over a field F and that T: V ---> W is a linear transformation. Show that for any v belonging to V that T(-v) = -T(v)
2. -T(v) denotes the additive inverse of T(v)
3. I think I'm really overcomplicating it =/ But i have
0v = T( v - v ) = T(v) + T(-v)
Then add -T(v)
0v + -T(v) = T(v) + T(-v)
(T(v) + T(-v)) -T(v) = T(v) + T(-v)
then
T(-v) = T(v) + T(-v)
then i suppose it could go to
T(-v) = 0v
but that doesn't help I'm going round in circles. Basically i need a starting point.
Looks more like you need someone to tell you when to stop. :smile:
When you obtain 0=T(v)+T(-v), you're done. If T(-v) has that property, it is the additive inverse of T(v). You should however explain more clearly why T(v+(-v))=0.
Hm, are you allowed to use that 0x=0 for all x without proof? If not, it's easy to prove using the trick 0x=(0+0)x.
Cheers!
Right so when i get:
0v = T(v) + T(-v)
i just move the T(v) over because 0v=0?
giving
-T(v) = T(-v)
seems a bit too easy! I've already proved 0x=0 .
Can you explain more about
'You should however explain more clearly why T(v+(-v))=0.'
please =]
You shouldn't need to move anything over, you know that 0v = 0, therefore at the step where you have T(v) + T(-v) = 0 that means T(-v) is the additive inverse of T(v), remember what definition of additive inverse is!
I'm not sure if I can tell you anything new without giving you the complete solution. What you want to prove is that T(v)+T(-v)=0. And the proof of that goes like this:
T(v)+T(-v)=T(v+(-v))=...=0
Can you fill in the missing steps?
  • · Replies 24 ·
