Proof of sin(θ-Φ)=sinθcosΦ-cosθsinΦ using vector algebra
The discussion revolves around proving the trigonometric identity sin(θ-Φ) = sinθcosΦ - cosθsinΦ using vector algebra, specifically through the manipulation of two unit vectors defined in a Cartesian coordinate system.
  • Participants explore the use of the cross product of two vectors to derive the identity. There are attempts to calculate the cross product and discussions about the implications of the direction of the vectors involved.
Some participants have provided insights into the calculation of the cross product and its components, while others are questioning the assumptions made regarding the signs and directions of the vectors. There is an acknowledgment of the relationship between the two vector products, axb and bxa, and how they relate to the proof.
Participants note that the vectors involved have zero "z" components, which is relevant to the calculation of the cross product. There is also mention of the right-hand rule and its significance in determining the direction of the resulting vector.
Jamiemma1995
given two unit vectors a= cosθi + sinθi b=cosΦi+sinΦj prove that sin(θ-Φ)=sinθcosΦ-cosΦsinθ using vector algebra[/B]
sin(θ-Φ)=sinθcosΦ-cosΦsinθ[/B]
axb= (cosθsinΦ-cosΦsinθ)k and I'm guessing that the change in sign has something to do with the fact that k is perpendicular to the vectors I'm usingΦ-θ[/B]
You could try a suitable rotation of axes, so that the cross product should still look the same.
The vectors a and b have zero "z" component. Remember how the components of the cross product are calculated.
when I calculated the components I got axb = ( cosθi +sinθj )x(cosΦi + sinΦj) axb=cosθcosΦixi + cosθsinΦixj +sinθcosΦjxi +sinθsinΦjxj ixi=1x1xsino=0 jxjxsin0=0 ixj=1x1sin90=1 and jxi=-1 because AxB=-BxA and was then left with axb= cosθsinΦ(1) + sinθcosΦ(-1)=cosθsinΦ -sinθcosΦ but its supposed to be the other way around, I don't understand where I'm going wrong :(
Think of the other definition of the cross product, how to get its direction applying right-had rule, so sin(θ-φ)=bxa.
https://www.mathsisfun.com/algebra/vectors-cross-product.html
oh I think I get it now so what your saying is although I could find axb and get the answer I got first , I could just as easily choose bxa as they're both the same but have opposite signs and so it still satisfies the proof.
The correct one is bxa.
Isn't (i + j) X (i + j) = j X i + i X j)
What is the sign of j X i ?
minus. Why do you ask? It was correct in Post#4.
9K
12K
