Proof the trig sum and difference identities
The discussion centers on understanding the sine and cosine sum and difference identities, particularly how to derive values like sin(75) without rote memorization. One participant expresses frustration with memorizing formulas and seeks a deeper understanding of why these identities work, suggesting a desire to grasp the underlying concepts rather than just memorize. Another contributor emphasizes that while understanding the proofs is valuable, memorization may be necessary for practical application, especially in exams. The conversation also touches on the relevance of these identities in calculus, indicating they may not be heavily featured but are important for broader mathematical applications. Ultimately, a solid grasp of these identities can enhance problem-solving skills in future studies.
nando94
My homework is to find the sin or cos value of angle that is not directly known on the unit circle. So of course we are given an equation which adds or subracts known values to get the desired one.
The problem is that I don't think memorizing them is helping me learn. I want to know how the sin(75) = sin(35+45) without readily memorizing them. So far what I did was draw a 30 degree triangle on the unit circle and then adjacent to the hypotenouse, I drew the 45 degree triangle. Then I drew a 75 degree triangle and tried to reason it through from the there but its not working. So can someone clarify why these identities work.
Have you studied complex numbers, and specifically DeMoivre's theorem? Because if you haven't, memorizing the formula is going to be a lot easier than proving it each time in your exam.
http://www.themathpage.com/atrig/sum-proof.htm
Nah my class is not that far yet. Everything is nearly culminating to calc now.
Then if you want to understand why the identities work, you'll have to work your way through the proof that I linked. If there are any parts you don't understand in the proof, you can always ask us to help clarify it for you :wink:
Or you can take the easy road out and just accept it, because in the end you'll still have to memorize the formula.
Thanks. I will check it out and see if it answers my question. I would rather take the hard road and understand what I am doing so that I can apply it better. Also are these identities used a lot in calc? I am going to take it next year.
Sure, I understand that.
Not so much in calc, but the trig sums continue to appear in many different applications throughout your schooling - even in college/university. So it's definitely worth memorizing. Try to get a feel for the patterns that sin(A+B) has as then cos(A+B). Tan always seemed to be the easiest to remember, maybe because it wasn't similar to any other trig.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
