Undergrad Proportion in 2D and 3D static equilibrium?
The discussion centers on the mathematical derivation of proportions in 2D and 3D static equilibrium involving a mass suspended by multiple ropes at various angles. Participants emphasize that the traditional method for solving these problems involves writing simultaneous equations to ensure the net force in each plane is zero. In 2D scenarios, two equations are typically required, while three equations are necessary for 3D problems. The conversation highlights that trigonometry plays a crucial role in determining the relationships between the distances and forces involved.
  • Understanding of static equilibrium principles
  • Familiarity with trigonometric functions
  • Ability to formulate and solve simultaneous equations
  • Basic knowledge of 2D and 3D vector analysis
  • Study the derivation of static equilibrium equations in 2D and 3D
  • Learn about the application of trigonometry in force analysis
  • Explore graphical methods for solving equilibrium problems
  • Investigate real-world applications of static equilibrium in engineering
Students and professionals in physics, engineering, and mathematics who are working with static equilibrium problems, particularly those involving multiple forces and angles.
Eric Wintjen
If you were to look at a simple 2D or 3D static equilibrium diagram, where a mass is suspended by multiple ropes at different angles, my gut feeling is that there is a fairly simple proportion between the distance between the center of mass and the rope (the distance created opposite of the angle) and the percentage of the total mass that rope is supporting. I have been unable to derive this proportion mathematically if it exists. If my instincts are correct, what is this proportion and how is it derived?
Its not clear what distance you mean. Can you post a diagram?
The traditional way of solving this type of problem is to realize that in order for the object to be stationary (not accelerating in any plane) then the net force in that plane must be zero.
So you write several simultaneous equations each summing the component forces in that plane to zero. Then solve them.
In a 2D problem you usually only need 2 equations. In. 3D problem you need 3.
I suggest you post a 2D example and your attempt to solve it so we can see where you are getting stuck.
It's not a simple proportion. Trigonometry is involved.
  • · Replies 35 ·
