Prove that the equation is an identity. State any restrictions.
  • Thread starter Thread starter goracheski
    Identity State
The equation cos(x)^2/(1+3sin(x)-4sin(x)^2)=(1+sin(x))/(1+4sin(x)) is being analyzed for identity verification. The denominator has been factored correctly into (1 - sin(x))(1 + 4sin(x)). To simplify the left side, it is suggested to use the identity cos^2(x) = 1 - sin^2(x). Further manipulation of both sides is needed to demonstrate that they are equivalent. The discussion emphasizes the importance of correctly factoring and applying trigonometric identities to prove the equation is an identity.
goracheski
We are taking a topic in math where you rearrange one side of the formula to match the other
I have factor 1+3sin(x)-4sin(x)^2 to get (-sin(x)+1)(4sin(x)+1)
if you rewrite 1 + 3 sin x -4 (sin x)^2 using u-sin x you get the quadratic - 4 u^2 + 3u +1 which is fairly easy to factor.
Continue working on the left side of your equation. What can you do with cos2(x). There's an identity you can use to change it.
The factors you found for the denominator are correct, but it would be better to write them as (1 - sin(x))(1 + 4sin(x)).
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
