Prove the equality using the theorems in determinants
  • Thread starter Thread starter plucker_08
    Determinants
plucker_08
without using any expansion method, prove the equality using the theorems in determinants...
Do you know Gaussian Elimination?
yup...but how can i use that?
Do you also know how elementary row operations affect the determinant of a matrix?
yes...
cud u give the solution? thnx!
