Prove the inequality - 1\4(ln2)^2 <= sigma(2^n\(2^(2^n)))
  • Thread starter Thread starter puzzek
    Inequality
puzzek
This is a question taken from an old exam so I am not sure to which subject in calculus it's connected to...
Prove the inequality:
\frac{1}{4(ln2)^2}\leq\sum\frac{2^n}{2^(2^n)}
(sigma is from 1 to +inf, and the Denominator on the right side is (2^(2^n))
Well, I solved it by calculating the first 3 elements of the sum showing their sum is larger than the left side, and that proves it. But, I don't think that's the way I suppose to solve it!
(I thought it somehow connected to derivative of the sum of the integrals of the function in the sigma.
Any help would be greatly appreciated.
There is nothing wrong with what you've done (noting that all terms of the series are positive). However, if it is that trivial, I would double check that you have the left hand side right. I don't see that a teacher would assign something that trivial.
PAllen,
Thank you for your response.
I double checked it again and it's exactly as it is written on my paper.
By the way, this is not that trivial, because in our test you are not allowed to use a calculator hence it's hard to calculate the value of (ln2)^2. One can still use some knowledge to evaluate it, but during an exam it's not that easy.
I still think I got it wrong and that's not the "proper" way to solve it. Is there any other direction?
puzzek said:
PAllen,
What is strange is how 'not close' the left side is. If you only use ln2 to 3 significant digits, and do computations guaranteed to be bounded above on the left and below on the right, you still trivially prove the inequality with 3 terms. I'll have to leave it so someone else to propose a non-computational proof. I don't see one at the moment.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
