Prove Trig Identity: A+B+C = 180 → 1+4 cosAcosBcosC
  • Thread starter Thread starter Harmony
    Identity
To prove the identity cos(A+B-C) + cos(B+C-A) + cos(C+A-B) = 1 + 4 cosA cosB cosC when A+B+C = 180, the initial approach involves substituting A+B-C with cos(180-2C), leading to cos(A+B-C) = -cos(2C). However, this does not yield the desired result directly. The discussion suggests using additional trigonometric identities, particularly the sum-to-product formulas, to simplify the left-hand side. Ultimately, the identity holds true, confirming the relationship between the angles and their cosine values.
Harmony
Question Statement
If A+B+C = 180, prove that cos (A+B-C) + cos (B+C-A) + cos (C+A-B) = 1+4 cosAcosBcosC
My Attempt
If A+B+C=180,
Then A+B-C=180-2C
cos (A+B-c)=cos(180-2C)
(After some substitution and caculation)
cos (A+B-C) = -cos 2C
Similarily, I obtain the same expression for cos (B+C-A), cos (C+A-B).
But that does not get me to the desire result.
Is my attempt wrong from the beginning?
No. Youre right. There is another trigo identity that you might find useful:
cos2a + cos2b + cos2c=-1-4cosa cosb cosc.
Have you covered the Sum to Product formulae?
\cos \alpha + \cos \beta = 2 \cos \left( \frac{\alpha + \beta}{2} \right) \cos \left( \frac{\alpha - \beta}{2} \right)
\cos \alpha - \cos \beta = -2 \sin \left( \frac{\alpha + \beta}{2} \right) \sin \left( \frac{\alpha - \beta}{2} \right)
\sin \alpha + \sin \beta = 2 \sin \left( \frac{\alpha + \beta}{2} \right) \cos \left( \frac{\alpha - \beta}{2} \right)
\sin \alpha - \sin \beta = 2 \cos \left( \frac{\alpha + \beta}{2} \right) \sin \left( \frac{\alpha - \beta}{2} \right)
So you've shown the LHS to be equal to:
- (cos (2A) + cos (2B) + cos(2C))
Using the identites above, we have:
- (\cos (2A) + \cos (2B) + \cos(2C)) = - (2 \cos(A + B) \cos(A - B) + \cos (2C)) = -(2 \cos(\pi - C) \cos (A - B) + 2 \cos ^ 2 C - 1)
= 1 - (- 2 \cos C \cos (A - B) + 2 \cos ^ 2 C) = ...
Can you go from here? :)
Heres a Trig Identity that you will find useful :
\mbox{If A+B+C = 180, then} \cos (A+B-C) +\cos (B+C-A) + \cos (C+A-B) = 1 + 4 \cos A \cos B \cos C.
LOL
Thanks a lot :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
