Proving a Group is Cyclic: What is the Generator of G?
  • Thread starter Thread starter zooxanthellae
    Cyclic Group
zooxanthellae
For each integer n, define f_{n} by f_{n}(x) = x + n. Let G = {f_{n} : n \in \mathbb{Z}}. Prove that G is cyclic, and indicate a generator of G.
None as far as I can tell.
Doesn't this require us to find one element of G such that, by applying that element over and over again e.g. f_n(f_n(...) we can produce any element of G? My main problem with this is I don't understand how one could find a way to go from positive to negative elements or vice-versa. For example if we let the generator be f(x) = x + 1 how could we generate f_{-1}(x) = x - 1? Or do I misinterpret the definition of G/requirements of a cyclic group?
Yes. Being a cyclic group means that the group can be generated by 1 element. But what does generated mean? Well, it means that if you take all compositions and all inverses, then you get the entire group.
So, in other words, a group G is cyclicly generated by x iff
G=\{...,x^{-3},x^{-2},x^{-1},e,x,x^2,x^3,...\}
So, in your example, you don't only allow compositions of the fn, but also inverses.
Oh, so then f_{1} = x + 1 is actually a generating group, since its inverse is f_{-1} = x - 1 and together these can account for any element of G.
Thanks much micromass, the book I'm using didn't specify (or I missed it if it did) that inverses are part of a generating group. That clears things up.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
