Proving Symmetry and Finding Conserved Quantities for Lagrangian Functions
The discussion revolves around proving symmetry in Lagrangian functions and identifying conserved quantities. The original poster presents a problem involving a Lagrangian L that depends on generalized coordinates, their time derivatives, and time itself, specifically focusing on the implications of an infinitesimal translation of the coordinate.
  • Participants discuss the method of proving symmetry by examining the change in the Lagrangian under an infinitesimal translation. There is mention of using a Taylor expansion to analyze the behavior of the Lagrangian after the transformation. Questions arise regarding the specifics of the Taylor series, particularly the choice of terms and parameters involved.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been offered regarding the use of Taylor expansion and the Euler-Lagrange equation to find conserved quantities, but there is no explicit consensus on the steps to take.
There is uncertainty regarding the proper procedure to prove symmetry and find conserved quantities, with participants questioning the definitions and assumptions related to the Taylor expansion and the variables involved.
sunmaggot
Given L (q, dq/dt, t).
translation: q ---> q + e (e is infinitesimal constant)
show that if ∂L/∂q = 0, then L is symmetry under the above translation.
then find conserved quantity.
S = ∫ L dt
My attempt is nothing... because I don't know the proper procedure to prove a symmetry. Do I simply prove L' - L = 0? But then the next part askes me to find conserved quantity. I have no idea how to find it...
So, can anyone spare me some hints...?[/B]
Let ##L_1=L_1(q, \dot{q}, t)## and ##L_2## that with the replacement ##q\rightarrow q+ \epsilon##. Now consider the expansion of ##L_2## in the infinitesimal parameter ##\epsilon##.
do you mean taylor expansion??
A conserved quantity means null time derivative of that quantity. Look at the Euler-Lagrange equation.
Yup :)
CAF123 said:
Yup :)
cool, I will try it first!
CAF123 said:
Yup :)
the taylor series has a term (x-a), what should be the a?
What should be the x?
x is q?
That's not what CAF123 suggested you to do. L is a function of phase space: you are interested in a small perturbation of the position variable, which changes the whole function L. So this means taking a McLaurin expansion in the infinitesimal translation parameter.
  • · Replies 0 ·
  • · Replies 30 ·
