Proving vector calculus identities using summation notation
lostminty
\frac{∂x_{i}}{∂x_{j}} = δ_{ij}
\vec{r} = x_{i}e_{i}
\frac{∂x_{i}}{∂x_{j}} = 1 iff i=j
δ_{ij} = 1 iff i=j
therefore
r^{2} = x_{k}x_{k}
\vec{r} = x_{k}e_{k}
\vec{r} = x_{j}e_{j}
r^{2} = x_{k}e_{k}\bulletx_{j}e_{j}
= e_{k}e_{j}x_{k}x_{j}
e_{k}e_{j} = δ_{jk} = 1 iff j=k
r^{2} = x_{k}x_{k} iff j=k
(\nablar^{2})_{j}= \frac{∂}{∂x_{j}}(x_{l}x_{l})= 2x_{j}
r^{2} = x_{k}x_{k}
pretty confused by now, so far I've guessed my way through.
is the j index communative? if so where did the l index come from. there is only 2 l's so maybe they cancel and you get x^{2} which differentiation gives 2x. and it inherits the i index from the d/dxi.
hi lostminty! :smile:
(try using the X2 button just above the Reply box :wink:)
δ_{ij} = 1 iff i=j
therefore
fine :smile:
no, the whole point of knowing that ∂xi/∂xj = ejek = δij
is that this notation enables you to avoid using those "iffs" …
ejekxjxk
= δjkxjxk
= xkxk :wink:
(and try the third one again)
Ok, sounds good.
so
3. Attempt at solving
(\nablar^{2})_{j}=
\frac{∂r^{2}}{∂x_{j}}=
\frac{∂}{∂x_{j}}(δ_{lm}x_{l}x_{m})=
\frac{∂}{∂x_{j}}(x_{l}x_{l}) =
\frac{∂}{∂x_{j}}(x^{2}) =
2x_{j}
lostminty said:
so
(\nablar^{2})_{j}=
ok so far :smile:
(though you could miss out the line with δ, it's not necessary)
no, you need to turn \frac{∂}{∂x_{j}}(x_{l}) into a δ :wink:
What does it equal if i\ne j? Don't you think you should say that?
δ_{ij} = 1 iff i=j
therefore
r^{2} = x_{k}x_{k}
r^{2} = x_{k}x_{k}
lostminty said:
Ok, sounds good.
so
(\nablar^{2})_{j}=
2x_{j}
hmmm
so
\frac{∂}{∂x}(x_{l}x_{l})_{j} =
\frac{∂}{∂x}(x_{l}^{2})_{j} =
\frac{∂}{∂x}x^{2}_{l}δ_{jl} =
if l=j δ_{jl}=1 else δ_{jl}=0
\frac{∂}{∂x}x^{2}_{j} =
2x_{j}
but that doesn't mean anything! :redface:
lostminty said:
hmmm
Still struggling with the concept. So I can use a kronecker delta to have the condition of index l being j...
\frac{∂}{∂x}(δ_{jl}x_{l}x_{l})_{j} =
( δ_{jl}=1 if l=j else 0)
\frac{∂}{∂x}x_{j}x_{j} =
2x_{j}
(just got up :zzz:)
you need a push-start :wink:
∂/∂xj (xlxl)
= (∂/∂xj xl) xl + xl (∂/∂xj xl)
= 2(∂/∂xj xl) xl
carry on from there :smile:
(just got up :zzz:)
∂/∂xj (xlxl)
= 2(∂/∂xj xl) xl
That makes sense! So you do it that way because you can't have x2 instead you do product rule
= 2(∂ xl/∂xj) xl
= δjlxl
if l=j
= 2xj
well I'll assume that's close to right and move onto the next problem which seems to make sense
\nabla\cdot \vec{r}=δii=3
∂xi/∂xjij
\nabla\cdot \vec{r}=\nabla_{i}r_{i}
= ∂/∂xiri
= ∂xi/∂xi = δii
=\sum between i=1 and 3 of δii
=\sum between i=1 and 3 of 1
= 1+ 1 + 1
=3
hi lostminty! :wink:
yes :smile:
= 2(∂ xl/∂xj) xl
= δjlxl
if l=j
= 2xj
that "if" line is unnecessary and wrong
stop putting "ifs" into your proofs! (what is it with you and "if"? :rolleyes: do you keep saying "if" in ordinary speech?)
the δ takes care of that!
(and you missed a "2" :wink:)
= ∂/∂xiri
= ∂xi/∂xi = δii
= 1+ 1 + 1
=3
yes that's fine :smile:
(though i'd be inclined to shorten the ending to just δii = 3 or δii = trace(δ) = 3)
This is another problem I'm a bit stuck on with similar content
F is a constant vector field. hence \nabla\cdot F = 0
this means there is a vector potential F = \nabla\times A
also \nabla\times F = 0
this means there is a scalar potential F = \nabla ∅
verify
∅ = F \cdot r
and
A = 1/2F x r
∅ = F \cdot r
= Firi
F = \nabla ∅
= \nabla (Firi)
= ∂/∂xk (Firi)
= (∂Fi/∂xk)ri + (∂ri/∂xk)Fisince \nabla\cdot F = 0
(∂Fi/∂xk)ri = 0
and
∂xi/∂xj = δij = 1 when j=i
(∂ri/∂xk)Fi = δikFiei = Fiei = F
verify
∅ = F \cdot r
and
A = 1/2F x r
F = \nabla\times A = \nabla\times1/2F x r
1/2F x r = 1/2εijkFjrk
F= \nabla\times 1/2εijkFjrk
= εimn∂/∂xi(1/2εijkFjrk)m
=∂/∂ximjδnknjδmk)(1/2Fjrk)m
=(1/2)∂/∂xi(Fmrn - Fnrm)m
hi lostminty!
verify
∅ = F \cdot r
∅ = F \cdot r
= Firi
F = \nabla ∅
no, leave out "F = " … that's what you're trying to prove!
= \nabla (Firi)
= ∂/∂xk (Firi)
no, you need to write either
(\nabla (Firi))_k
= ∂/∂xk (Firi)​
or
\nabla (Firi)
= ∂/∂xk (Firi) e_k​
fine :smile:
(∂Fi/∂xk)ri = 0
no, that doesn't follow at all, does it? :redface:
((∂Fi/∂xk) has nothing to do with \nabla\cdot F)
you need the stronger condition, that F is constant
and
you're doing it again! :rolleyes:
using "when" is the same as using "if"!
just write "∂xi/∂xj = δij"
where did those e's suddenly come from?
if you were going to use them, they should have been there from the beginning :wink:
(i'll look at the other one later)
