Proving vector calculus identities using the levi-civitia symbol
The discussion revolves around proving a vector calculus identity involving the divergence of the cross product of two vector fields, \(\nabla \bullet (\textbf{A} \times \textbf{B})\), using the Levi-Civita symbol and Einstein summation convention. Participants are exploring the mathematical framework and implications of this identity within the context of vector calculus.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the application of the Levi-Civita symbol in the context of the identity, with some questioning the implications of repeated indices and the behavior of partial derivatives. There are suggestions to express the identity in terms of the Levi-Civita symbol and manipulate it to find connections between both sides of the equation.
The discussion is ongoing, with participants providing insights and clarifications regarding the manipulation of indices and the properties of the Levi-Civita symbol. Some participants are attempting to rearrange terms and explore the implications of their manipulations, while others are questioning assumptions and interpretations of the mathematical expressions involved.
Participants are navigating potential confusion regarding the differentiation of vector components and the application of the Levi-Civita symbol, indicating a need for clarity on these mathematical concepts. There is also mention of issues with formatting in the discussion, which may affect the readability of mathematical expressions.
CmdrGuard
Prove [tex]\nabla \bullet (\textbf{A} \times \textbf{B}) = \textbf{B} \bullet (\nabla \times \textbf{A}) - \textbf{A} \bullet (\nabla \times \textbf{B})[/tex]
I'd like to prove this using the levi-civitia symbol: [tex]\epsilon_{ijk}[/tex] and einstein-summation convention as practice and because it seems the most elegant way to deal with problems like these.
[tex](\textbf{A} \times \textbf{B})_i = \epsilon_{ijk} a_j b_k[/tex]
What follows is what I get so far:
[tex]\nabla \bullet (\textbf{A} \times \textbf{B}) = \frac{\partial}{\partial x_i}(\textbf{A} \times \textbf{B})_i = \frac{\partial}{\partial x_i} \epsilon_{ijk} A_j B_k = \epsilon_{ijk} \left[ A_j \frac{\partial B_k}{\partial x_i} + B_k \frac{\partial A_j}{\partial x_i} \right][/tex]
Now don't the partial derivatives with respect to [tex]x_i[/tex] force [tex]k = i[/tex] in the first sum and [tex]j = i[/tex] in the second sum? I must be doing something wrong because if so, then this equality becomes zero which is not correct.
What am I doing wrong?
tex doesn't seem to be working, so i can;t read your post...
first call nabla g then you want to show
g.(AxB) = B.(gxA) - A.(xB)
so first express in terms of
g.(AxB) = (d/dx_k)(e_ijk A_i B_j)
then expand using product rule
The levi-civitia symbol sets repeated indices to zero, so it would be the opposite of what you say, in the sense that when k or j do equal i, the element goes to zero. I think you might have mistaken the levi-civitia symbol for the kronecker delta symbol...
That goes for what you're doing wrong, but as for the proof, I tried for a little bit to do it and sort of got somewhere, but it probably wouldn't help much. I'd suggest writing out the right hand side in terms of the einstein summation and the lc symbol and then manipulating the two until you start to see the similarities, that will probably guide you as to the correct connecting path between the two sides.
Although I think after looking at it that this way of manipulating the identity is perhaps not the most elegant way when the standard proof is probably much simpler.
ok so now i can read the tex
[tex] \nabla \bullet (\textbf{A} \times \textbf{B}) <br /> = \frac{\partial}{\partial x_i}(\textbf{A} \times \textbf{B})_i <br /> = \frac{\partial}{\partial x_i} \epsilon_{ijk} A_j B_k <br /> = \epsilon_{ijk} \left[ A_j \frac{\partial B_k}{\partial x_i} + B_k \frac{\partial A_j}{\partial x_i} \right][/tex]
now i would continue rearranging as
[tex] = \epsilon_{ijk} A_j \frac{\partial B_k}{\partial x_i} + \epsilon_{ijk}B_k \frac{\partial A_j}{\partial x_i}[/tex]
then to clarify change some dummy indicies and rearrange for clarity
[tex] = \epsilon_{ijk} A_j \frac{\partial B_k}{\partial x_i} + \epsilon_{mnp}B_p \frac{\partial A_n}{\partial x_m}[/tex]
[tex] = A_j (\epsilon_{ijk} \frac{\partial }{\partial x_i} B_k)+ B_p (\epsilon_{mnp}\frac{\partial }{\partial x_m} A_n)[/tex]
then a have a think about the definition of the cross product in index notation, in particular the ordering of indexes.
not too sure what you mean here, but my answer is no.
Think of [itex]A_k = A_k(x_1, x_2, x_3)[/itex] then differentiate. The fact that both i & k are repeated in the levi cevita symbol means you sum over that index
You're confusing
[tex]\frac{\partial A_j}{\partial x_i}[/tex]
with
[tex]\frac{\partial x_j}{\partial x_i}[/tex]
The latter is equal to δij, so only the i=j terms survive when you sum over one of the indices. But that's not what you have in this problem.
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 0 ·
