Pushing a cabinet on a rough floor
  • Thread starter Thread starter judas_priest
When pushing a filing cabinet across a rough floor at constant speed, the force exerted must equal the frictional force, which is less than the cabinet's weight due to the coefficient of kinetic friction being less than one. The discussion clarifies that if the applied force is doubled, the cabinet would not maintain constant speed but would instead accelerate, indicating that the sixth statement is false while the seventh is true. The concept of equilibrium is emphasized, showing that a body can be in motion at constant speed when the forces are balanced. The net force becomes non-zero when the applied force exceeds the frictional force, leading to acceleration. Understanding these principles is crucial for solving related physics problems effectively.
judas_priest
You are pushing a filing cabinet horizontally across a rough floor (μk = 0.37) in a straight line at a constant speed. Which of the following statements about the magnitudes of the forces acting on the filing cabinet are correct?
1) The force that you exert on the filing cabinet will be more than its weight?
2) The force that you exert on the filing cabinet will be equal to the frictional force on the cabinet
3) The force that you exert on the filing cabinet will be equal to its weight
4) The force that you exert on the filing cabinet will be less than its weight
5) The force that you exert on the filing cabinet will be more than the frictional force on the cabinet
6) If you exerted twice the force, the cabinet would slide at a constant speed that is twice the original value
7) If you exerted twice the force, the cabinet would accelerate across the floor
1 I know is false, because cabinet is moving at a constant speed, hence F = μMg
2 is true because F = μMg (Constant speed)
3 is false. Less than it's weight. Because μ is less than 1
4 true. Because μ is less than 1
5 I have a doubt about this one. Will it be true? Because, to keep it at constant speed A force constant force greater than frictional force is required
6 Not sure
7 Not sure.
Please correct me where I'm wrong and give me an idea about 6th and 7th
1. Correct, because ##\mu_k < 1##. 2 to 4 are also correct.
5. How can this be true if 2 is also true?
6. Would there be an unbalanced net force on the cabinet in this case? What does F = ma tell you?
7. See 6.
7. See 6.
I'm assuming 6 is true, 7 is false.
Because if it's moving at twice the constant speed, it's obviously not accelerating.
I had the exact same doubt about 5th. But if it wasn't greater than frictional force, and just equal to it, wouldn't it just stay in equilibrium?
No! Why would you assume that?
Perhaps it's better to start at the start. What do Newton's first two laws of motion state?
So what exactly is equilibrium? Does it necessarily mean a body is at rest? Can a body be in motion and still remain in equilibrium?
I'm a terrible teacher
No, it doesn't mean body is at rest, here equilibrium implies to keep the body at a constant speed AGAINST the frictional force. So does that mean a force that would be equal to frictional force be able to do that?
Also, I'm still not clear about 6th and 7th. If twice the force exerted is applied constantly, it'd slide at a constant speed. (according to first law). But it's no where mentioned that it is applied constantly. Does that mean if twice the force was exerted, the applied force would decrease? Hence, making 6th false and 7th true (because it is decelerating)
Constant velocity (which also implies constant speed), so yes, correct. If the force you exert is equal in magnitude and exactly opposite in direction to the frictional force, the body will be in equilibrium. In this case, equilibrium means the cabinet moves in a straight line at constant speed.
If twice the force were exerted, what would be the *net* force on the object?
The frictional force remains constant at ##\mu_kMg##.
Initially, the force you applied was the same: ##\mu_kMg##. The net force was zero. This meant the cabinet *was* in equilibrium, traveling at constant velocity.
Now, the force you're applying is ##2\mu_kMg##. So what's the net force on the cabinet now?
What does ##F = ma## tell you?
When ##a## is nonzero, can an object move with constant velocity?
Are you implying
F - μkMg= Ma?
Hence, 2μkMg - μkMg = Ma
Therefore, a = μkg?
Okay, so are 6 and 7 true? I just worked out again, and I get them as true.
But again, 6 says " the cabinet would slide at a constant speed that is twice the original value " . Do they mean twice the original value of speed? How do I prove that? I'm clear about 7th.
If you think the 7th is true, then the 6th certainly can't be true. What do you think?
Yup, you're right. I still can't understand the 6th one though. Rest is very clear.
If 6th isn't true then you don't have to understand it. Do you? The 7th says the cabinet will accelerate, so it can't have a constant velocity.
judas_priest said:
Are you implying
F - μkMg= Ma?
Therefore, a = μkg?
Yes. ##a = \mu_kg##. (BTW, you should learn to do subscripts properly in LaTex, otherwise it looks like k is a constant you're multiplying everything by. Here, the subscript k refers to "kinetic friction").
So if there's a nonzero acceleration, 7 is clearly true. Agreed?
Can 6 be true if 7 is true?
