Putting together a wave function from given data
The discussion revolves around determining the wave function for a transverse sinusoidal wave given specific parameters, including period, speed, and initial conditions. Key equations for wave properties, such as angular frequency and wave number, are introduced, with emphasis on deriving amplitude and phase angle from the initial conditions. A suggestion is made to derive the wave equation first, allowing for simultaneous solving of amplitude and phase angle using the provided data. The importance of organizing the approach to solve for unknowns is highlighted. Overall, the conversation emphasizes a systematic method to construct the wave function from the given data.
Pyrestrike
Hi all, I've got a question I think I understand conceptually but not mathematically...
A transverse sinusoidal wave on a string has a period T = 25.0 ms and travels in a negative x direction with a speed of 30.0 m/s.
At t=0, a particle on the string at x=0 has a transverse position of 2.00 cm and is traveling downward with a speed of 2.00 m/s.
So, I put together the given data as:
T = 0.025 s
v = 30.0 m/s
y' = 0.02 m
x' = 0m
t' = 0s
v(tangent) = -2.00 m/s
* the (') denotes initial condition
a) What is the amplitude of the wave?
b) What is the initial phase angle?
c) What is the maximum transverse speed of the string?
d) Write the wave function for the wave.
a) Okay, so my initial (and really only) idea on how to tackle finding amplitude is:
EQ 1
y = A sin (kx - ωt)
where A is amplitude, k is the wave number, omega is angular frequency, and t is time. I want to use the initial conditions y', x', and t' to try and find A, since they're all given and the latter two equal 0, but I found that would make sin(0), which is undefined. From there, I really don't know if I'm even on the right track for finding A, or if there is a formula that I'm missing to help find it.
b) I would use the general expression of the above sinusoidal wave, where phi is attached to the end of the sine function. The only problem is that again A needs to the found.
c) Finding v(max) would just be using the velocity of an object in harmonic motion:
EQ 2
v = -ω A sin *(ωt + Φ)
d) This is obviously just plugging in the appropriate values into EQ 1
My big problem is just where to start (unless there's something wrong with my logic on the other three parts). I have an inclination that I need to solve for λ, k, and ω using the following equations:
EQ3: λ = vT
EQ4: k = (2π) / λ
EQ5: ω = (2π) / T
But I don't know how to apply them to finding A, so in the end I'm still in a confused mess. Can anyone guide me in at what I might be missing?
Thanks in advance!
--Brian
I'd simply try to find the wave equation instead of going through the parts bit by bit... once you have the equation, you can simply answer all the questions...
The general wave equation is:
y = A sin (kx - ωt + phi)
you can get w immediately from T... like you showed using w = 2*pi/T. Then you can also get k, using v = w/k. v is given as -30.
so now you're left with getting A and phi.
dy/dt = -wAcos(kx - wt + phi)
you're given y and dy/dt at t = 0, x = 0... plug into the above equations... then you have 2 equations with 2 unknowns. solve for A and phi.
Gah! Wow, I've gotten the whole "do things in order" bit by my past physics teachers that I didn't even think of that... Thanks muchly!
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
