PV diagram, ranking heat transfer between 4 processes
The discussion focuses on ranking the heat transferred in four thermodynamic processes using a pV diagram. Participants analyze the equations related to thermal energy, work done by the gas, and the first law of thermodynamics. Specific attention is given to calculating the changes in internal energy (ΔEth), work done (Wgas), and the absolute value of heat transfer (|Q|) for the processes, particularly from state 3 to 4. Clarifications are sought on why certain values are presented in specific formats, and the importance of understanding isothermal processes is emphasized. The conversation ultimately aims to resolve discrepancies in the calculations and solidify the understanding of heat transfer in these processes.
HoboBones
Rank the magnitude of the heat transferred with the gas in each of the four processes.
First law of thermodynamics
Thermal energy
Ideal gas law
Work done by gas
Work in isothermal
Apologies, made a mistake when posting. Please see below post.
Problem and pV diagram
Problem: Rank the magnitude of the heat transferred with the gas in each of the four processes.
Given pV diagram
Attempt at solution with my questions in red
Equations used:
Thermal energy: Eth=3/2nRT
Ideal gas law: pV=nRT
Workby gas=area under curve
Work in isothermal: Wgas,isothermal=nRTln(Vf/Vi)
First law of thermodynamics applied to gases: ΔEth=Q-Wgas
Set up:
From ideal gas law, pV=nRT. Thus,
ΔEth=3/2nRT=3/2pV
Wgas, isothermal=nRTln(Vf/Vi)=pVln(Vf/Vi)
ΔEth=Q-Wgas --> Q=ΔEth+Wgas
Solving for ΔEth, Wgas, and |Q| for the processes: (I don't understand why we are solving for absolute value of Q)
I need some help solving for ΔE, Wgas, and |Q| for process 3->4
Process
ΔEth
Wgas
|Q|
1->2​
-9pV​
-6pV​
15pV​
2->3​
3/2(-pV)​
0​
1.5pV​
3->4​
0pV​
4->5​
3/2(pV)​
pV​
2.5pV​
Here is my attempt at process 3->4
ΔEth3->4 = 3/2(2pV-2pV) = 0 (My professor has the answer as "0pV" and not 0, not sure why?
Wgas,isothermal= area under the curve?
Area of triangle + Area under rectangle = 2pV? (correct answer is -pVln(Vf/Vi)
|Q| = -pVln(2V/V) = 1.4pV (I am not sure how this is the correct answer)
Any help would be much appreciated!
##dW=pdV.## Replace ##p## using the ideal gas law and integrate. Note that "isothermal" means "constant ##T##."
Update, I think I figured it out but not really understanding
For process 3->4,
Wgas,isothermal = area under curve = 1/2bh + Arectangle = 2pV
We can plug in our area into the work in isothermal equation, thus
Wgas,isothermal = -pVln(Vf/Vi) = -2pVln(2V/V)
|Q| = ΔEth(3->4) + Wgas,isothermal = 0pV -2pVln(2V/V) = |-1.386pV| = 1.4pV
She doesn't want us to use integrals unfortunately
Integrals was plan A. Plan B says call the heat entering the gas during the isothermal part ##Q_{34}.## Add an extra row to the table that completes the cycle from 5 to 1 with an isochoric process. Calculate the new entries the same way you did step 2 to 3. Now add all 5 elements in each column. Note that ##W_{34}=Q_{34}## so you have one equation and one unknown, ##Q_{34}.## There is no plan C.
